CTB922VG/4R
CTB922VG/4R
    CAMDENBOSS
    CAMDENBOSS - CTB922VG/4R - Pluggable Terminal Block, 5 mm, 4 Ways, 24AWG to 12AWG, 3.3 mm², Screw, 1...
CTB922VG/4R 数据手册
CAMBLOCK 5mm Pitch Pluggable Rising Clamp Terminal Blocks PCB TERMINAL BLOCKS • 2-24 pole solid block • Pluggable male-female connectors • Open & closed headers • Horizontal & vertical female plug styles • Polarised mouldings • Moulded in green UL94-V0 flame retardant PA66 • Professional rising clamp terminals • 0.2-3.3mm2 (24-12AWG) solid & stranded cable • Captive screws • Guided pin alignment • C US approved SPECIFICATION Rating Insulation resistance Withstand voltage Contact resistance Working temperature Mouldings Wire protector Screw/torque Recommended PCB hole size 15A 300V 1000M Ω/1000V AC1000V/1min 20m Ω -40°C to +105°C UL94-V0 flame retardant PA66 Tin plated, phosphor bronze M3 steel, tin plated 0.4Nm ø1.4mm Female Connector CTB9202/8 CTB9202/9 CTB9202/10 CTB9202/11 CTB9202/12 CTB9202/13 CTB9202/14 CTB9202/15 CTB9202/16 CTB9202/17 CTB9202/18 CTB9202/19 CTB9202/20 CTB9202/21 CTB9202/22 CTB9202/23 CTB9202/24 POLES 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 LENGTH 10mm 15mm 20mm 25mm 30mm 35mm CTB9202 40mm 45mm 50mm 55mm 60mm 65mm 70mm 75mm 80mm 85mm 90mm 95mm 100mm 105mm 110mm 115mm 120mm 8.1 17.6 TYPE NO. CTB9202/2 CTB9202/3 CTB9202/4 CTB9202/5 CTB9202/6 CTB9202/7 8.1 Female Connector Vertical (standard) LENGTH 10mm 15mm 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm 65mm 70mm 75mm 80mm 85mm 90mm 95mm 100mm 105mm 110mm 115mm 120mm CTB922VG/S We operate a constant improvement policy, our products are subject to change without notice. 50 EL EC T RO N IC S & ENC LOSURES Ver 1 +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com 12.4 CTB922VG/14S CTB922VG/15S CTB922VG/16S CTB922VG/17S CTB922VG/18S CTB922VG/19S CTB922VG/20S CTB922VG/21S CTB922VG/22S CTB922VG/23S CTB922VG/24S POLES 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25.9 TYPE NO. CTB922VG/2S CTB922VG/3S CTB922VG/4S CTB922VG/5S CTB922VG/6S CTB922VG/7S CTB922VG/8S CTB922VG/9S CTB922VG/10S CTB922VG/11S CTB922VG/12S CTB922VG/13S CAMBLOCK Female Connector Vertical (reversed) LENGTH 10mm 15mm 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm 65mm 70mm 75mm 80mm 85mm 90mm 95mm 100mm 105mm 110mm 115mm 120mm CTB922VG/R PCB TERMINAL BLOCKS 25.9 POLES 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 12.4 TYPE NO. CTB922VG/2R CTB922VG/3R CTB922VG/4R CTB922VG/5R CTB922VG/6R CTB922VG/7R CTB922VG/8R CTB922VG/9R CTB922VG/10R CTB922VG/11R CTB922VG/12R CTB922VG/13R CTB922VG/14R CTB922VG/15R CTB922VG/16R CTB922VG/17R CTB922VG/18R CTB922VG/19R CTB922VG/20R CTB922VG/21R CTB922VG/22R CTB922VG/23R CTB922VG/24R PCB Mounting Male Vertical (closed ended) POLES 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 LENGTH 11.2mm 16.2mm 21.2mm 26.2mm 31.2mm 36.2mm 41.2mm 46.2mm 51.2mm 56.2 61.2mm 66.2mm 71.2mm 76.2mm 81.2mm 86.2mm 91.2mm 96.2mm 101.2mm 106.2mm 111.2mm 116.2mm 121.2mm CTB9302 1.0x1.0 35.0±0.2 5.0 +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com 12.2±0.1 3.9±0.2 3.7 TYPE NO. CTB9302/2 CTB9302/3 CTB9302/4 CTB9302/5 CTB9302/6 CTB9302/7 CTB9302/8 CTB9302/9 CTB9302/10 CTB9302/11 CTB9302/12 CTB9302/13 CTB9302/14 CTB9302/15 CTB9302/16 CTB9302/17 CTB9302/18 CTB9302/19 CTB9302/20 CTB9302/21 CTB9302/22 CTB9302/23 CTB9302/24 30.0 We operate a constant improvement policy, our products are subject to change without notice. Ver 1 51 EL EC T RO N IC S & ENC LOSURES
CTB922VG/4R 价格&库存
很抱歉,暂时无法提供与“CTB922VG/4R”相匹配的价格&库存,您可以联系我们找货
