P C B T E R M I N A L B LO C KS
S TA N D A R D
SCREWLESS
PLUGGABLES
ECONOMY RANGE
3.81mm pitch pluggable rising
clamp terminal blocks
Product overview
15
3
12.2mm
CTB922HE/4
4
16mm
CTB922HE/5
5
19.8mm
CTB922HE/6
6
23.7mm
CTB922HE/7
7
27.5mm
CTB922HE/8
8
31.3mm
CTB922HE/9
9
35.1mm
CTB922HE/10
10
38.9mm
CTB922HE/11
11
42.7mm
CTB922HE/12
12
46.5mm
PA R T N O .
POLES
LENGTH
CTB922VE/2S
2
8.4mm
CTB922VE/3S
3
12.2mm
CTB922VE/4S
4
16mm
CTB922VE/5S
5
19.8mm
CTB922VE/6S
6
23.7mm
CTB922VE/7S
7
27.5mm
CTB922VE/8S
8
31.3mm
CTB922VE/9S
9
35.1mm
CTB922VE/10S
10
38.9mm
CTB922VE/11S
11
42.7mm
CTB922VE/12S
12
46.5mm
PA R T N O .
POLES
LENGTH
CTB922VE/2R
2
8.4mm
CTB922VE/3R
3
12.2mm
CTB922VE/4R
4
16mm
CTB922VE/5R
5
19.8mm
CTB922VE/6R
6
23.7mm
CTB922VE/7R
7
27.5mm
CTB922VE/8R
8
31.3mm
CTB922VE/9R
9
35.1mm
CTB922VE/10R
10
38.9mm
CTB922VE/11R
11
42.7mm
CTB922VE/12R
12
46.5mm
Tin plated
Screw/torque
M2 steel, tin plated 0.2Nm
Recommended PCB hole size
ø1.4mm
CTB922HE
6.5
6.5
CTB922VE S
Length
1.7
19.2
CTB922HE/3
UL94-V0 flame retardant PA66
Wire protector
12.6
8.4mm
-33°C to +120°C
Mouldings
6.6
LENGTH
2
20m Ω
Working temperature
15.5
POLES
CTB922HE/2
AC2000V/1min
Contact resistance
11.2
PA R T N O .
5000M Ω/1000V
Withstand voltage
2.3
3.81
10.36
E CO N O M Y R A N G E P C B T E R M I N A L B LO C KS
8A 125 V
Insulation resistance
2.5
2-12 pole solid block
Up to 20 poles available
Pluggable male-female connectors
Professional rising clamp terminals
Closed headers
Polarised mouldings
Moulded in green UL94-V0 flame
retardant PA66
0.13-1.3mm2 (26-16AWG) solid &
stranded cable
Captive screws
Guided pin alignment
approved
2.75
S P E C I F I C AT I O N
Rating
code side
CTB922VE R
Length
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 1
FM 28614
EMS 613558
SCREWLESS
PLUGGABLES
S TA N D A R D
ECONOMY RANGE
CTB932VE/3
3
12.22mm
CTB932VE/4
4
16.03mm
CTB932VE/5
5
19.84mm
CTB932VE/6
6
23.65mm
CTB932VE/7
7
27.46mm
CTB932VE/8
8
31.27mm
CTB932VE/9
9
35.08mm
CTB932VE/10
10
38.89mm
CTB932VE/11
11
42.7mm
CTB932VE/12
12
46.51mm
PA R T N O .
POLES
LENGTH
CTB932HE/2
2
8.41mm
CTB932HE/3
3
12.22mm
CTB932HE/4
4
16.03mm
CTB932HE/5
5
19.84mm
CTB932HE/6
6
23.65mm
CTB932HE/7
7
27.46mm
CTB932HE/8
8
31.27mm
CTB932HE/9
9
35.08mm
CTB932HE/10
10
38.89mm
CTB932HE/11
11
42.7mm
CTB932HE/12
12
46.51mm
CTB932VE
2.3
2.3
CTB932HE
2.3
2.3
8.41mm
3.5
LENGTH
2
7.0
POLES
CTB932VE/2
7.0
PA R T N O .
FM 28614
EMS 613558
Vers 1
16
很抱歉,暂时无法提供与“CTB932HE/2”相匹配的价格&库存,您可以联系我们找货
