CTBP0758/2
CTBP0758/2
    CAMDENBOSS
    Conn Terminal Block F 2 POS 5.08mm Solder RA Thru-Hole 20A
CTBP0758/2 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D PLUGGABLES SCREWLESS 002 PCB TERMINAL BLOCKS 081 TERMINAL STRIPS 5.08mm pitch high power 90° rising clamp terminal blocks Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS CTBP0758 • 2 and 3 pole double interlocking mechanism for increased strength • Professional rising clamp terminals • High profile 90° mounting • Moulded in green UL94-V0 flame retardant PA66 • Cable acceptance - 0.4-2mm2 (26-12AWG) • 20A 300V • Guided pin alignment • C approved US , Insulation resistance 158 INTERFACE MODULES AND RELAY BASES Withstand voltage Contact resistance UL=20A/300V, VDE=20A/250V 500M Ω/500V AC2000V/1min 20mΩ (max) Working temperature -40°C to +105°C Moulding UL94-V0 flame retardant PA66 Pin/terminal Rising clamp Screw/torque Recommended PCB hole size Tin plated brass Brass, nickel plated M3 steel, zinc plated 0.5Nm ø1.6mm PA R T N O . POLES LENGTH CTBP0758/2 2 10.16mm CTBP0758/3 3 15.24mm CTBP0758/4 4 20.32mm CTBP0758/5 5 25.4mm CTBP0758/6 6 30.48mm CTBP0758/7 7 35.56mm CTBP0758/8 8 40.64mm CTBP0758/9 9 45.72mm CTBP0758/10 10 50.8mm CTBP0758/11 11 55.88mm CTBP0758/12 12 60.96mm 10.5 Rating 5.08 18 S P E C I F I C AT I O N 0.8 IP68 CONNECTORS 5.3 151 K E Y F E AT U R E S | Double interlock mechanism CONNECT High powered 20A 36 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 | Professional rising clamp
CTBP0758/2 价格&库存
很抱歉,暂时无法提供与“CTBP0758/2”相匹配的价格&库存,您可以联系我们找货
