CTBP5050/3
CTBP5050/3
    CAMDENBOSS
    Conn Terminal Block F 3 POS 5mm Solder RA Thru-Hole 16A
CTBP5050/3 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D SCREWLESS PLUGGABLES 002 TERMINAL STRIPS Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS 158 INTERFACE MODULES AND RELAY BASES • • • • • • • • • CTBP5050 2 and 3 pole interlocking Wire protector terminals Low profile 90° mounting Moulded in UL94-V0 flame retardant PA66 Cable acceptance - 0.6-1.6mm2 (2214AWG) Guided pin alignment Test probe facility Anti solder wicking terminal approved US , C S P E C I F I C AT I O N PA R T N O . POLES LENGTH Rating UL=16A/250V, VDE=24A/250V CTBP5050/2 2 10mm Insulation resistance 500M Ω/500V CTBP5050/3 3 15mm Withstand voltage AC2000V/1min CTBP5050/4 4 20mm CTBP5050/5 5 25mm CTBP5050/6 6 30mm CTBP5050/7 7 35mm CTBP5050/8 8 40mm CTBP5050/9 9 45mm CTBP5050/10 10 50mm CTBP5050/11 11 55mm CTBP5050/12 12 60mm Contact resistance Working temperature 20mΩ (max) -40°C to +105°C Moulding UL94-V0 flame retardant PA66 Pin/terminal Tin plated brass Wire protector Phosphor bronze, nickel plated Screw/torque M2.5 steel, zinc plated 0.4Nm Recommended PCB hole size ø1.2mm Ø1 5.0 7.6 3.5 0.5 10 081 5mm pitch low profile 90° screw terminal blocks 2.7 PCB TERMINAL BLOCKS K E Y F E AT U R E S | 90 Degree orientation CONNECT Wire protector terminals | Interlock mechanism 18 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614 EMS 613558
CTBP5050/3 价格&库存
很抱歉,暂时无法提供与“CTBP5050/3”相匹配的价格&库存,您可以联系我们找货
