CTBPTDVG/2
CTBPTDVG/2
    CAMDENBOSS
    Conn Terminal Block F 6 POS 5mm Solder ST Thru-Hole 15A
CTBPTDVG/2 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS 5mm triple decker rising clamp terminal blocks Product overview 081 TERMINAL STRIPS CTBPTDVG • T  riple decker terminals • Moulded in green UL94-V0 flame retardant PA66 • 2.5mm2 - IEC • 30-14 AWG - UL • Professional rising clamp terminals • Guided pin alignment • C approved US , 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 Rating UL=15A/300V VDE=18A/250V Insulation resistance Withstand voltage 500M Ω/500V AC2000V/1min Contact resistance 20mΩ (max) Working temperature -40°C to +105°C Moulding UL94-V0 flame retardant PA66 Pin/terminal Tin plated brass Rising clamp Brass, nickel plated Screw/torque M2.5 steel, zinc plated 0.4Nm Recommended PCB hole size ø1.5mm PA R T N O . POLES LENGTH CTBPTDVG/2 6 12.5mm CTBPTDVG/3 9 17.5mm CTBPTDVG/4 12 22.5mm CTBPTDVG/5 15 27.5mm CTBPTDVG/6 18 32.5mm CTBPTDVG/7 21 37.5mm IP68 CONNECTORS 5 5 0.60 17.50 15 0.60 158 INTERFACE MODULES AND RELAY BASES 25.20 36.60 14 CTBPTDVG/8 24 42.5mm CTBPTDVG/9 27 47.5mm CTBPTDVG/10 30 52.5mm CTBPTDVG/11 33 57.5mm CTBPTDVG/12 36 62.5mm *3.50±0.3 S P E C I F I C AT I O N 10.16 0.80 15.24 31.8 4.9 5 0.9 K E Y F E AT U R E S | Tr i p l e d e c k e r t e r m i n a l s | Professional rising clamp CONNECT F l a m e r e t a r d a n t PA 6 6 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 EMS 613558 Vers 2.31 Vers 31
CTBPTDVG/2 价格&库存
很抱歉,暂时无法提供与“CTBPTDVG/2”相匹配的价格&库存,您可以联系我们找货
