CTSN431/12W
CTSN431/12W
    CAMDENBOSS
CTSN431/12W 数据手册
INTERCONNECTION PCB TERMINAL BLOCKS INTERCONNECTION FUSES & FUSEHOLDERS LEDS & INDICATORS MINIATURE SWITCHES LIMIT & SAFETY SWITCHES 12 Way Nylon Terminal Strips • Moulded  from Natural PA6 (standard, CTSN400), Cream PA66 (CTSN500,) Grey PA66 Glass fibre (CTSN600) • Available with or without wire protection • UL94-V2 Self extinguishing as standard • V0 types pass 960°C glowwire test • Easily cut to size • Can also be supplied pre-cut • Can be printed on request • Closed inserts (middle barrier) option • Captive terminal screws •  , , & approvals Standard Type CONTROL PRODUCTS INTERFACE MODULES & SUPPORTS RELAY BASES PITCH / UL RATING 8mm/20A 8mm/15A 10mm/30A 10mm/20A 12mm/50A 12mm/30A 14mm/65A 14mm/65A 15mm/85A TYPE NO. CTSN431/12W CTSN431/12 CTSN433/12W CTSN433/12 CTSN434/12W CTSN434/12 CTSN435/12W CTSN435/12 CTSN438/12W Raised Base ENCLOSURES BATTERIES TRANSFORMERS PITCH / UL RATING 8mm/20A 8mm/20A 10mm/30A 10mm/30A 12mm/50A 12mm/50A 14mm/65A 14mm/65A TYPE NO. CTSN431/12WR CTSN431/12R CTSN433/12WR CTSN433/12R CTSN434/12WR CTSN434/12R CTSN435/12WR CTSN435/12R PITCH / UL RATING 10mm/30A 10mm/30A 10mm/30A 10mm/30A 10mm/30A 10mm/30A 10mm/30A 10mm/30A CTSN431-433 450VAC CTSN434-438 750VAC (UL600VAC) CTSN400 -30°C to +110°C CTSN500 -30°C to +110°C CTSN600 -5°C to +180°C CTSN400 UL94-V2 PA6 CTSN500 UL94-V0 PA66 CTSN600 UL94-V0 PA66 + GF Nickel-plated brass Zinc-plated steel CQ-15 Stainless steel Working temperature Moulding Standard insert Terminal screws Wire protectors Part Numbers shown are for standard PA6 material (e.g. CTSN433/12) For CSTN500 PA66 material change first number to 5 (e.g. CTSN533/12) For CSTN600 PA66+GF material change first number to 6 (e.g. CTSN633/12) WIRE PROTECTION No Yes No Yes No Yes No Yes No INSERT DIAMETER 3.2mm 3.2mm 3.5mm 3.5mm 4.4mm 4.4mm 6.0mm 6.0mm 7.5mm CABLE ACCEPTANCE 4.0mm2/12AWG 2.5mm2/14AWG 6.0mm2/10AWG 4.0mm2/12AWG 10.0mm2/8AWG 6.0mm2/10AWG 16.0mm2/6AWG 10.0mm2/8AWG 25.0mm2/4AWG TERMINAL SCREWS M3 M3 M3 M3 M3.5 M3.5 M4 M4 M5 LENGTH 94mm 94mm 116mm 116mm 140mm 140mm 166mm 166mm 180mm WIDTH 18mm 18mm 21mm 21mm 23mm 23mm 29mm 29mm 31mm HEIGHT 15.5mm 15.5mm 16mm 16mm 18.5mm 18.5mm 23mm 23mm 27.5mm PITCH 8mm 8mm 9.95mm 9.95mm 12mm 12mm 14mm 14mm 15mm FIXING HOLE DIAMETER 2.8mm 2.8mm 2.8mm 2.8mm 2.8mm 2.8mm 3.5mm x 6.4 slot 3.5mm x 6.4 slot 3.4mm MAX CURRENT 32A 32A 41A 41A 57A 57A 76A 76A 101A WIRE PROTECTION No Yes No Yes No Yes No Yes INSERT DIAMETER 3.2mm 3.2mm 3.5mm 3.5mm 4.4mm 4.4mm 6.0mm 6.0mm CABLE ACCEPTANCE 4.0mm2/12AWG 2.5mm2/14AWG 6.0mm2/10AWG 4.0mm2/12AWG 10.0mm2/8AWG 6.0mm2/10AWG 16.0mm2/6AWG 10.0mm2/8AWG TERMINAL SCREWS M3 M3 M3 M3 M3.5 M3.5 M4 M4 LENGTH 94mm 94mm 116mm 116mm 140mm 140mm 166mm 166mm WIDTH 18mm 18mm 21mm 21mm 23mm 23mm 29mm 29mm HEIGHT 17.2mm 17.2mm 17.8mm 17.8mm 20.5mm 20.5mm 25.8mm 25.8mm PITCH 8mm 8mm 10mm 10mm 12mm 12mm 14mm 14mm FIXING HOLE DIAMETER 2.8mm 2.8mm 2.8mm 2.8mm 2.8mm 2.8mm 3.5mm x 6.4 slot 3.5mm x 6.4 slot MAX CURRENT 32A 32A 41A 41A 57A 57A 76A 76A INSERT DIAMETER 3.5mm 3.5mm 3.5mm 3.5mm 3.5mm 3.5mm 3.5mm 3.5mm CABLE ACCEPTANCE 6.0mm2/10AWG 4.0mm2/12AWG 6.0mm2/10AWG 4.0mm2/12AWG 6.0mm2/10AWG 4.0mm2/12AWG 6.0mm2/10AWG 4.0mm2/12AWG TERMINAL SCREWS M3 M3 M3 M3 M3 M3 M3 M3 LENGTH 116mm 116mm 116mm 116mm 116mm 116mm 116mm 116mm WIDTH 31mm 31mm 31mm 21mm 21mm 21mm 21mm 21mm HEIGHT 16.8mm 16.8mm 21.5mm 17.6mm 17.3mm 17.3mm 18.1mm 18.1mm PITCH 10mm 10mm 10mm 9.95mm 10mm pin 10mm pin 9.95mm 9.95mm FIXING HOLE DIAMETER 2.8mm 2.8mm 2.8mm 3.6mm 3.5mm drill 3.5mm drill 2.8mm 2.8mm MAX CURRENT 41A 41A 41A 41A 41A 41A 41A 41A Alternative Options TYPE NO. CTSN433/12WL CTSN433/12L CTSN433/12WLC CTSN433/12LC CTSN433/12WS CTSN433/12S CTSN433/12WQ CTSN433/12Q SPECIFICATION Voltage CTSN WIRE PROTECTION No Yes No Yes No Yes No Yes Ver 1.0 Iss 1 EL EC T RO N IC S & ENC LOSURES We operate a constant improvement policy, our products are subject to change without notice. +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com INTERCONNECTION CTSN433/12T fast fixing hole between poles Standard type, no wire protection PCB TERMINAL BLOCKS INTERCONNECTION FUSES & FUSEHOLDERS CTSN433/12TR fast fixing hole between poles and raised base Raised base types - provides increased isolation LEDs & INDICATORS MINIATURE SWITCHES LIMIT & SAFETY SWITCHES  TSN433/12LC larger isolating surface per pole and screw tower. C Complies with EN60598/1 4.7 and 11.2 CTSN433/12TRG fast fixing hole between poles, raised base and socket in the base CONTROL PRODUCTS INTERFACE MODULES & SUPPORTS RELAY BASES  TSN433/12L larger isolating surface per pole (750V, test voltage 3,000V) C Complies with EN60598/1 4.7 and 11.2 CTSN433/12S fixing pin ENCLOSURES BATTERIES TRANSFORMERS CTSN433/12Q fixing hole between poles and wide base terminal connection +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Ver 1.0 EL EC T RO N IC S & ENC LOSURES
CTSN431/12W 价格&库存
很抱歉,暂时无法提供与“CTSN431/12W”相匹配的价格&库存,您可以联系我们找货
