CVB-PLUS1
CVB-PLUS1
    CAMDENBOSS
    CAMDENBOSS - CVB-PLUS1 - Plastic Enclosure, DIN Rail, DIN Rail, Nylon, 112 mm, 22.5 mm, 99 mm
CVB-PLUS1 数据手册
D I N R A I L E N C LOS U R E S Ve r t i c a l D I N R a i l e n c l o s u r e s : CVB-PLUS1 P r o d u c t overview CVB-PLUS1V CVB-PLUS1 • 22.5mm wide vertical DIN Rail mount housing • Clip together design for fast assembly • Supplied with four 4-pole 5mm pitch pluggable terminal blocks • 16 positions • Moulded in Green UL94-V0, PA6 Nylon • Front and side label recesses • Solid and vented versions available • Top hat 35mm DIN Rail or surface mounting S P E C I F I C AT I O N Rating terminals 15A 300V Contact resistance 20mΩ Insulation resistance 500mΩ/DC500V Withstand voltage AC2000V/1min Materials Pin head Housing Terminal block See page 403 for terminal block specification Brass, tin plated Green UL94-V0 PA6 Nylon PA R T N O . DESCRIPTION LENGTH W I DT H HEIGHT CVB-PLUS1 Solid sides 112mm 22.5mm 99mm CVB-PLUS1V Vented sides 112mm 22.5mm 99mm K I T PA R T D E S C R I P T I O N NUMBER OF PIECES Enclosure Base Sides 2 Enclosure Lid 1 Metal DIN Rail Clips 1 Spring 1 5mm 4 pole Female Terminal Block 4 5mm 4 pole Male Terminal Block - Left Side 2 5mm 4 pole Male Terminal Block - Right Side 2 54.58 36.15 ACC E SS O R I E S 14.50 33 CVB-plus pcb D I N R A I L E N C LOS U R E S • Material: 2-layer FR4 • X826 1.3mm diameter holes • X16 1.5mm diameter holes (reserved for terminal blocks) 400 PA R T N O . DESCRIPTION LENGTH W I DT H HEIGHT CVB-PLUS-PCB PCB 80mm 99.2mm 1.6mm 99.15 Ø1.45 Ø1.10 80 CVB-plus metal earth clip PA R T N O . DESCRIPTION • Replaces one of the black DIN clips to offer earthing from PCB to DIN Rial. CVB-PLUS-MC Metal earth clip +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. 1 Vers 4 FM 28614 D I N R A I L E N C LOS U R E S Ve r t i c a l D I N R a i l e n c l o s u r e s : Te r m i n a l b l o c k s ( i n c l u d e d w i t h C V B - P l u s a s PA R T N O . DESCRIPTION SPECIFICATION CVBP9200/4-GY Female terminal block Rating terminals 15A 300V CVBP935L/4-GY Male left side terminal block Contact resistance 20mΩ CVBP935R/4-GY Male right side terminal block Insulation resistance 500mΩ/DC500V Withstand voltage AC2000V/1min Materials Pin header Housing Wire range 1.5mm2 (28-14AWG) solid and stranded cable Approvals UL and VDE standard) Brass, tin plated PA66, UL94-V0 CVBP9200/4-GY 5.01 20 5.87 15 3.20 18.10 8.90 2.96 9.50 5.80 1.12 1.10 2.93 5 5 0.90 2.02 5 9.77 8.33 For exact product information see page.62 20 CVBP935L/4-GY 3.2 14.7 5 5 5.9 1.1 5 12.2 4.4 5 5 16.5 15.3 11.5 6.5 5 2.9 1.7 1.5 20 CVBP935R/4-GY 7.2 17.2 3.2 D I N R A I L E N C LOS U R E S 14.7 7.2 5.9 5 1.1 5 5 4.4 5 15.3 8.6 9.8 2.9 1.7 16.5 11.5 6.5 1.5 5 5 12.2 17.2 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 Vers Vers 21 401
CVB-PLUS1 价格&库存
很抱歉,暂时无法提供与“CVB-PLUS1”相匹配的价格&库存,您可以联系我们找货
