CAX19VPA1
CAX19VPA1
    CAMDENBOSS
CAX19VPA1 数据手册
1C9A”BC IN AEBTI S N EATNSDAENNDC E LN OC SU LO RS EU S RES 19’’ desktop enclosures Product overview C19DE Sturdy lightweight 19” enclosures designed to accept ‘full-width’ 84E subracks and standard 19” units. • • • • • Heights from 2U up to 9U Constructed from 1mm steel Supplied with front tilt-feet, rear fixed feet Ventilation slots in base and rear panel Recessed side handles for comfort and easy transport • Supplied flat-packed • Open front design • Front options ordered separately U W I DT H HEIGHT LENGTH 2U 489mm 131.5mm 330mm C19DE2450 2U 489mm 131.5mm 450mm C19DE3330 3U 489mm 176mm 330mm C19DE3450 3U 489mm 176mm 450mm C19DE6330 6U 489mm 306mm 330mm C19DE6450 6U 489mm 306mm 450mm C19DE9450 9U 489mm 443mm 450mm W H PA R T N O . C19DE2330 1C9A”BC IN AEBTI S N EATNSDAENNDC E LN OC SU LO RS EU S RES S P E C I F I C AT I O N 428 Materials Shell 1mm thick steel Handles ABS Legs ABS Standard colours Shell: epoxy paint graphite grey Handles: black similar to RAL 9004 Legs: dark grey similar to RAL 7016 Standard unit includes Top and bases covers Two side panels One rear panel Four feet 19” mounting brackets Handles Mounting hardware Options 19" front panels K E Y F E AT U R E S Lightweight | Sturdy | Supplied flat-packed +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 L 1 9 ” C A B I N E TS A N D E N C LOS U R E S ACC E SS O R I E S 19” Aluminium front panel • 3mm thick aluminium, clear anodised S TA N DA R D F R O N T VENTED FRONT U HEIGHT(MM) CAX19SPS1 CAX19VPS1 1U 43.6mm CAX19SPS2 CAX19VPS2 2U 88.1mm CAX19SPS3 CAX19VPS3 3U 132.5mm CAX19SPS4 CAX19VPS4 4U 177.0mm CAX19SPS5 CAX19VPS5 5U 221.5mm CAX19SPS6 CAX19VPS6 6U 265.9mm CAX19SPS9 CAX19VPS9 9U 399.2mm S TA N DA R D F R O N T VENTED FRONT U HEIGHT(MM) CAX19SPA1 CAX19VPA1 1U 43.6mm CAX19SPA2 CAX19VPA2 2U 88.1mm CAX19SPA3 CAX19VPA3 3U 132.5mm CAX19SPA4 CAX19VPA4 4U 177.0mm CAX19SPA5 CAX19VPA5 5U 221.5mm CAX19SPA6 CAX19VPA6 6U 265.9mm CAX19SPA9 CAX19VPA9 9U 399.2mm 19” Steel front panel • Manufactured in steel • Powder coated (RAL 7016) • M6x15mm screw, PA washer, M6 caged nut PA R T N O . DESCRIPTION CAX000001 Attachment set (pack of 4) 1C9A”BC IN AEBTI S N EATNSDAENNDC E LN OC SU LO RS EU S RES Attachment set +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 429
CAX19VPA1 价格&库存
很抱歉,暂时无法提供与“CAX19VPA1”相匹配的价格&库存,您可以联系我们找货
