CIRCULAR CONNECTORS
PLUGS
SOCKETS
ACC E SS O R I E S
002
PCB
TERMINAL
DIECAST
BLOCKS
ACCESSORIES
081
TERMINAL STRIPS
095
WIRE TO BOARD
CONNECTORS
100
CIRCULAR
CONNECTORS
151
IP68 CONNECTORS
Push-pull connectors cable
mounted plug CCA1 series
C C A 1 P 1 /A 0 5
5 pole
CCA1P1/A05
• Premium range of circular connectors
• IP68 sealed using vacuum technology
(when connected and using
environmental cable clamp)
• Tough, high performance interconnection
solution
• Ideal for harsh and extreme environments
• Suitable for broadcasting, autosport,
military, rail, marine, security, industrial
and agricultural applications
• Key coded to prevent misconnection
• Will not disconnect when the cable is
under load or stress
• Tested to IEC 60512-3-5a
S P E C I F I C AT I O N
PA R T N O .
DESCRIPTION
POLES
SERIES
CCA1P1/A05
Cable mounted
plug
5
CCA series
158
INTERFACE
MODULES AND
RELAY BASES
~36
Ø5.2
9.3
~26
7
Shell style/model
Cable mounted straight plug,
male contact
Codes
Code 1
Contact type
Solder type
Contact diameter
0.7mm
Max. stranded conductor
AWG 21-22
Max diameter
0.79mm
Vtest (contact-shell)
800V(AC) 1300V(DC)
Vtest (contact-contact)
1000V(AC) 1800V(DC)
Rated current
5.2A
Rated voltage
≤160V
Mechanical operation
5000 mating cycles
Housing material
Brass (natural chrome plated)
shell and collet nut, nickel
plated brass latch sleeve and
mid pieces
Insulator
PPS
Contacts
Brass (gold plated)
Humidity (max)
72 hr
Climatical category
50/175/21
Shielding (min)
75 dB (10 MHz)
Shielding (min)
40 dB (1 GHz)
IP rating
IP68 (when connected and
using
8
This product should be used with
the following cable clamps:
PA R T N O .
WIRE RANGE
CCV1C/CC
2.6 - 3.1mm
CCV1C/CD
3.1-3.6mm
CCV1C/CE
3.6-4.1mm
CCV1C/CF
4.1-4.3mm
1
Non IP68 cable clamps also available
ACC E SS O R I E S
Metal cap for plugs
PA R T N O .
DESCRIPTION
CCA12
Camcirc metal cap for plug A1
A S S O C I AT E D P R O D U C T S
CONNECT
C C E 1 S 1 / 0 5
C C M 1 S 1 / 0 5
C C T 1 S 1 / 0 5
104
- C C M s e r i e s A 1 s i z e s o c k e t
- C C E s e r i e s A 1 s i z e s o c k e t
- C C T s e r i e s A 1 s i z e s o c k e t
page 123
page 141
p a g e 1 47
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 1
FM 28614
很抱歉,暂时无法提供与“CCA1P1/A05”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+221.60261
- 5+217.17696
- 10+212.73945
- 25+208.31381
- 50+203.87630
- 100+199.45065
