CCA1P1/A09
CCA1P1/A09
    CAMDENBOSS
    CAMDENBOSS - CCA1P1/A09 - Circular Connector, IP68, Shielded, CamCirc CCA Series, Cable Mount Plug, ...
CCA1P1/A09 数据手册
Multi-Pole Connectors Push-Pull Connectors Cable Mounted Plug Part Number: CCA1P1/A09 CCA Series Illustration Pole: 9 Size Drawing Insert Con�iguration Technical Data Common Values Shell Style/Model: Codes: Contact Type: Contact Diameter: Electrical Values Cable mounted straight plug, male contact Code 1 Solder type 0.5mm Material Housing Material: Insulator: Contacts: Others Brass (natural chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces PPS Brass (Gold plated) Max. Stranded Conductor :AWG26-28 Humidity (max): Vtest (contact-contact): 1100V(AC) 1800V(DC) Salt Spray Corrosion: >72 hr Mechanical Operation: 5000 mating cycles Max Diameter: Vtest (contact-shell): Rated Current: Rated Voltage: CamdenBoss Ltd. Ver 1.2 0.43mm 800V(AC) 1200V(DC) 1.7A ≤160V
CCA1P1/A09 价格&库存
很抱歉,暂时无法提供与“CCA1P1/A09”相匹配的价格&库存,您可以联系我们找货
CCA1P1/A09
    • 1+342.35490
    • 10+332.06603
    • 20+321.80840
    • 50+314.96651
    • 100+308.10379
    库存:27
