ACC E SS O R I E S
SOCKETS
PLUGS
CIRCULAR CONNECTORS
002
PCB TERMINAL
DIECAST
DIECAST
BLOCKS
ACCESSORIES
ACCESSORIES
Push-pull connectors female
cable mount CCT series
CCT1S1/05
5 pole
CCT1S1/05
• Premium range of circular connectors
• IP68 sealed using vacuum technology
(when connected and using
environmental cable clamp)
• Tough, high performance interconnection
solution
• Ideal for harsh and extreme environments
• Suitable for broadcasting, autosport,
military, rail, security and industrial
applications
• Key coded to prevent misconnection
• Will not disconnect when the cable is
under load or stress
• Cable mounting
• Tested to IEC 60512-3-5a
• Cable clamp required for use with this
series
S P E C I F I C AT I O N
PA R T N O .
DESCRIPTION
POLES
SERIES
CCT1S1/05
Female cable
mount
5
CCT series
Ø10
Ø5.1
~35
7
1
081
TERMINAL STRIPS
7
Shell style/model
Free cable mount socket
connector, female contact
Codes
Code 1
Contact type
Solder type
Contact diameter
0.7mm
Max. stranded conductor
AWG 21-22
Max diameter
0.79mm
Vtest (contact-shell)
800V(AC)
1300V(DC)
Vtest (contact-contact)
1000V(AC)
1800V(DC)
Rated current
5.2A
Rated voltage
≤160V
Mechanical operation
5000 mating cycles
Housing material
Brass (natural chrome
plated) shell and collet nut,
nickel plated brass latch
sleeve and mid pieces
Insulator
PPS
Contacts
Brass
(gold plated)
Humidity (max)
72 hr
Climatical category
50/175/21
Shielding (min)
75 dB (10 MHz)
Shielding (min)
40 dB (1 GHz)
IP rating
IP68 (when connected
and using
095
WIRE TO BOARD
CONNECTORS
100
CIRCULAR
CONNECTORS
151
IP68 CONNECTORS
158
INTERFACE
MODULES AND
RELAY BASES
K E Y F E AT U R E S
Key coded
| Cable mounting socket
This product should be
used with the following
cable clamps:
Cable clamps required
PA R T N O .
WIRE RANGE
CCV1C/CC
2.6 - 3.1mm
CCV1C/CD
3.1-3.6mm
CCV1C/CE
3.6-4.1mm
CCV1C/CF
4.1-4.3mm
ACC E SS O R I E S
Metal and rubber caps for sockets
PA R T N O .
DESCRIPTION
CCT11
Camcirc metal cap for sockets A1
PA R T N O .
DESCRIPTION
CCT12
Camcirc rubber cap for sockets A1
CONNECT
Non IP68 cable clamps also available
A S S O C I AT E D P R O D U C T S
C C A 1 P 1 /A 0 5
- C C A S e r i e s A 1 s i z e p l u g
page 104
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
FM 28614
Vers 1
147
很抱歉,暂时无法提供与“CCT1S1/05”相匹配的价格&库存,您可以联系我们找货
