FOOT SWITCHES
178
MICROSWITCHES
DIECAST
ACCESSORIES
Heavy duty footswitch
182
TACTILE SWITCHES
Product overview
186
22MM CONTROL
SWITCHES
191
FOOT SWITCHES
193
LIMIT SWITCHES
• Industrial die-cast footswitch for heavy duty
applications
• Snap action and slow action contact blocks
1 NO + 1 NC
• Rising saddle-washer terminal connections
• Single or double-pole contact blocks
• Positive opening operation
• Silver contacts
• Anti-slip foot pedal
• Non-slip rubber feet
• Supplied with cable gland
• Manufactured to meet the requirements of
IP65
approved
S P E C I F I C AT I O N
Contact block rated
10A
Insulation voltage (Ui)
500VAC 600VDC
Utilisation categories
Q300
A600
Protection against short circuits
Fuse 10A 500V type aM
Alternate current: AC15 (50-60Hz)
Ui (V)
Ie (A)
250 400 500
6 4
Direct current: DC13
Ui (V)
Ie (A)
24 125 250
6 1.1 0.4
Connectors flexible wire sizes
min - 1 x 0.5 mm2 (1 x AWG 20)
max - 2 x 2.5mm2 (2 x AWG 14)
Actuating force
Single snap action
Single slow action
Double snap action
Double slow action
Ambient temperature
From -25°C to +80°C
Weight
Guarded
Unguarded
203
69VA, 125-250VDC
720VA, 120-600VAC
10N
12N
13N
15N
1.4 kg
0.55 kg
PIEZO SWITCHES
AND KEYPADS
Guarded footswitch
PA R T N O .
TYPE
CFSHC1
Guarded 1 snap action contact block - 1NO
+ 1NC
CFSHC2
Guarded 1 slow action contact block - 1NO
+ 1NC
CFSHC1C1
Guarded 2 snap action contact blocks - 2x
1NO + 1NC
CFSHC2C2
Guarded 2 slow action contact blocks - 2x
1NO + 1NC
CFSHC1C2
Guarded 1 snap and 1 slow action contact
155mm
CFSH
240mm
150mm
blocks 2x 1NO + 1NC
Un-guarded footswitch
PA R T N O .
TYPE
CFUHC1
Unguarded 1 snap action contact block - 1NO
+ 1NC
CFUHC2
Unguarded 1 slow action contact block - 1NO
+ 1NC
CFUHC1C1
Unguarded 2 snap action contact blocks - 2x
1NO + 1NC
CFUHC2C2
Unguarded 2 slow action contact blocks - 2x
1NO + 1NC
CFHUHC1C2
Unguarded 1 snap and 1 slow action contact
blocks - 2x 1NO + 1NC
75mm
CFUH
210mm
60mm
K E Y F E AT U R E S
Double or single contacts
SWITCH
NO or NC contact blocks | Snap action or slow action |
192
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 1
FM 28614
EMS 613558
很抱歉,暂时无法提供与“CFSHC1”相匹配的价格&库存,您可以联系我们找货
