UNIVERSAL ENCLOSURES
7000 Series Recessed Designer Cases
Functional yet modern design in nine different sizes
with anti-scratch finish. Used by leading OEMs across
numerous industries.
• Lid and base moulded in ABS
• Lid mounted by four M3 machine screws
• Plastic screw covers for aesthetic appearance
• Fine texture anti-scratch finish
• Recesses in lid and base designed to accept membrane
keypads or overlays
• Integral mounting guides in lid and base for vertical
PCB mounting
• PCB pillars in lid and base
• Surface mountable via moulded fixing points or
wall-mounting kit (optional)
• Option of gasket included (For IP65)
• Option of RFI and gasket (For IP65 and RFI shielding)
universal
Enclosures
Specification
Materials
Operating Temperature
Protection class
Lid, base & screw covers ABS, UL94-V0
Resistant to temperatures of up to 85°C
IP54 as standard
IP65 with gasket option
Grey
Base & lid
4x M3 Machine screws (Torque 0.5 Nm)
4x Screw covers
Wall mounting kit
IP65 gasket kits
RFI Screening
Standard colours
Standard unit includes
Options
hand
held
cases
heavy
duty
enclosures
DIN
Rail
Boxes
Grey
CRDCG0001
CRDCGG001
CRDCERG01
CRDCG0002
CRDCGG002
CRDCERG02
CRDCG0003
CRDCGG003
CRDCERG03
CRDCG0004
CRDCGG004
CRDCERG04
CRDCG0005
CRDCGG005
CRDCERG05
CRDCG0006
CRDCGG006
CRDCERG06
CRDCG0007
CRDCGG007
CRDCERG07
CRDCG0008
CRDCGG008
CRDCERG08
CRDCG0009
CRDCGG009
CRDCERG09
Length
90mm
90mm
90mm
90mm
90mm
90mm
110mm
110mm
110mm
127mm
127mm
127mm
127mm
127mm
127mm
145mm
145mm
145mm
190mm
190mm
190mm
220mm
220mm
220mm
220mm
220mm
220mm
width
55mm
55mm
55mm
55mm
55mm
55mm
85mm
85mm
85mm
75mm
75mm
75mm
75mm
75mm
75mm
90mm
90mm
90mm
120mm
120mm
120mm
145mm
145mm
145mm
145mm
145mm
145mm
Height
25mm
25mm
25mm
40mm
40mm
40mm
35mm
35mm
35mm
30mm
30mm
30mm
45mm
45mm
45mm
45mm
45mm
45mm
60mm
60mm
60mm
50mm
50mm
50mm
80mm
80mm
80mm
Description
Designer Case
With Gasket
With RFI & Gasket
Designer Case
With Gasket
With RFI & Gasket
Designer Case
With Gasket
With RFI & Gasket
Designer Case
With Gasket
With RFI & Gasket
Designer Case
With Gasket
With RFI & Gasket
Designer Case
With Gasket
With RFI & Gasket
Designer Case
With Gasket
With RFI & Gasket
Designer Case
With Gasket
With RFI & Gasket
Designer Case
With Gasket
With RFI & Gasket
Interface
supports
control
stations
diecast
& metal
boxes
Desktop &
Instrument
cases
Potting
Boxes
19"
ENCLOSURES
* This series is available in Black on request
19''
CABINETS
7000-IP Gasket kits
Wall mounting kit
• Universal design fits all sizes, available in grey
• Fits lid and base, surface 1.5mm from lid or 9.5mm base
Grey
CRDCWMKIT
description
4x mounting feet
• EPDM gasket, dust and water protection from
IP54 to IP65
type no.
CRDCGASK1
CRDCGASK2
CRDCGASK3
CRDCGASK4
CRDCGASK5
CRDCGASK6
Description
Gasket for Designer Case Size 1 and 2
Gasket for Designer Case Size 3
Gasket for Designer Case Size 4 and 5
Gasket for Designer Case Size 6
Gasket for Designer Case Size 7
Gasket for Designer Case Size 8 and 9
DEVELOPMENT
BOARD
ENCLOSURES
custom
sized
enclosures
Custom
Services
+44 (0)1638 716101
info@camdenboss.com
www.camdenboss.com
We operate a constant improvement policy,
our products are subject to change without notice.
2
Ver 1.0 Iss 7
ELEC T RON IC S & ENC LOSURES
很抱歉,暂时无法提供与“CRDCGG007”相匹配的价格&库存,您可以联系我们找货
