CST06S08H
CST06S08H
    CAMDENBOSS
CST06S08H 数据手册
Miniature Switches 6x6mm Tact Switches • • • • • • Advanced switch technology Positive tactile action Tamper proof application Flow solder washaway cleaning Through-hole PCB, surface mount & horizontal terminals Square & round button styles • • PCb terminal blocks Other button heights available Can be supplied taped for auto-insertion, add suffix /T Specification Rating Contact resistance Insulation strength Electrical life Temperature range Operating force Material Terminals CST06S00T CST06S00S CST06S00H Case Button Contacts 50mA/12VDC 100mΩ max 100MΩ min/500VDC 30,000 operations min 30,000 operations min 100,000 operations min -10°C to +60°C 160 ± 70g Nylon Nylon Phosphor Bronze Silver Plated Brass Silver Plated Interconnection fuses & Fuseholders LEDs & Indicators Through-hole PCB Terminals Type No. CST06S0AT CST06S43T CST06S05T CST06S73T CST06S08T CST06S95T CST06S13T Button height 7.4mm 4.3mm 5mm 7.3mm 8mm 9.5mm 13mm Button SIZE 2.4 x 2.4mm Miniature switches CST06S0AT CST06S0AT ø3.4mm ø3.4mm ø3.4mm ø3.4mm ø3.4mm ø3.4mm limit & Safety switches control products CST06ST CST06ST Interface modules & supports relay bases Surface Mount Terminals Type No. CST06S43S CST06S05S CST06S08S Button Height 4.3mm 5mm 8mm CST06SS enclosures Suffix /T = Tape & Reel batteries transformers Horizontal PCB Terminals Type No. CST06S43H CST06S05H CST06S08H Button Height 4.3mm 5mm 8mm CST06SH CST06S Series Replaces CB001 Series Example CST0650AT replaces CB001A Example CST06543S replaces CB001-IFS Example CST35643T replaces CB004FS +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. 133 Ver 1.0 ELEC T RON IC S & ENC LOSURES
CST06S08H 价格&库存
很抱歉,暂时无法提供与“CST06S08H”相匹配的价格&库存,您可以联系我们找货
