CTB0100/3
CTB0100/3
    CAMDENBOSS
CTB0100/3 数据手册
PCB Terminal blocks 5mm Pitch Standard Profile Rising Clamp Terminal • • • • • • • • • 2 & 3 pole double Interlocking mechanism for increased strength 4-12 pole solid block end stackable Moulded in green UL94-V0 flame retardant PA Professional rising clamp terminals 0.2-4.0mm2 (30-12AWG) solid cable 0.2-2.5mm2 (30-12AWG) stranded cable Guided pin alignment Captive screws , , , approved Specification Rating CTB0100 Dielectric strength Impulse withstand voltage Working temperature Moulding Pin/terminal Wire clamp Screw/torque Recommended PCB hole size PCb terminal blocks 24A/250V UL=14A/300V, VDE&IMQ=24A/250V ≥2kV 4kV 110°C UL94-V0 flame retardant PA Tinned, nickel plated brass Nickel plated brass M3 steel zinc plated, 0.5Nm ø1.3mm 2  & 3 pole double interlocking mechanism for increased strength 4-12 pole solid block end stackable Moulded in green UL94-V0 flame retardant PA Professional rising clamp terminals 0.2-4.0mm2 (30-12AWG) • • • • solid cable 0.2-2.5mm2 (30-12AWG) stranded cable Guided pin alignment Captive screws , , , approved fuses & Fuseholders LEDs & Indicators Type No. CTB0100/2 CTB0100/3 CTB0100/4 CTB0100/5 CTB0100/6 CTB0100/7 CTB0100/8 CTB0100/9 CTB0100/10 CTB0100/11 CTB0100/12 Poles 2 3 4 5 6 7 8 9 10 11 12 Miniature switches Length 10mm 15mm 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm limit & Safety switches control products Interface modules & supports 5mm Pitch Standard Profile 90˚ Rising Clamp Terminal • • • • • Interconnection Specification Rating CTB0150 Dielectric strength Impulse withstand voltage Working temperature Moulding Pin/terminal Wire clamp Screw/torque Recommended PCB hole size Type No. CTB0150/2 CTB0150/3 CTB0150/4 CTB0150/5 CTB0150/6 CTB0150/7 CTB0150/8 CTB0150/9 CTB0150/10 CTB0150/11 CTB0150/12 +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com Poles 2 3 4 5 6 7 8 9 10 11 12 Length 10mm 15mm 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm 24A/250V UL=14A/300V, VDE&IMQ=24A/250V ≥2kV 4kV 110°C UL94-V0 flame retardant PA Tinned, nickel plated brass Nickel plated brass M3 steel zinc plated, 0.5Nm ø1.3mm relay bases enclosures batteries transformers For other dimensions see CTB0100 We operate a constant improvement policy, our products are subject to change without notice. 15 ELEC T RON IC S & ENC LOSURES
CTB0100/3 价格&库存
很抱歉,暂时无法提供与“CTB0100/3”相匹配的价格&库存,您可以联系我们找货
