CTB9400/2
CTB9400/2
    CAMDENBOSS
CTB9400/2 数据手册
PCB TERMINAL BLOCKS PCB TERMINAL BLOCKS INTERCONNECTION FUSES & FUSEHOLDERS 7.5mm & 7.62mm Pitch Pluggable Rising Clamp Terminal Blocks • 2-12 pole solid block • Pluggable male-female connectors • Open & closed headers • Horizontal female plug style • Polarised mouldings • Moulded in green UL94-V0 flame retardant PA • Professional rising clamp terminals • 0.2-2.5mm2 (30-12AWG) solid & stranded cable • Anti solder wicking • Captive screws • Guided pin alignment • , , approved 7.5mm 7.62mm SPECIFICATION Rating Dielectric strength Impulse withstand voltage Working temperature Moulding Pin/terminal Rising clamp Screw/torque Recommended PCB hole size LEDs & INDICATORS MINIATURE SWITCHES LIMIT & SAFETY SWITCHES CONTROL PRODUCTS TYPE NO. CTB9400/2 CTB9400/3 CTB9400/4 CTB9400/5 CTB9400/6 CTB9400/7 CTB9400/8 CTB9400/9 CTB9400/10 CTB9400/11 CTB9400/12 POLES 2 3 4 5 6 7 8 9 10 11 12 LENGTH 13mm 20.5mm 28mm 35.5mm 43mm 50.5mm 58mm 65.5mm 73mm 80.5mm 88mm TYPE NO. CTB9408/2 CTB9408/3 CTB9408/4 CTB9408/5 CTB9408/6 CTB9408/7 CTB9408/8 CTB9408/9 CTB9408/10 CTB9408/11 CTB9408/12 POLES 2 3 4 5 6 7 8 9 10 11 12 LENGTH 13.2mm 20.9mm 28.5mm 36.1mm 43.7mm 51.3mm 59mm 66.6mm 74.2mm 81.8mm 89.4mm CTB9400 INTERFACE MODULES & SUPPORTS RELAY BASES DIN RAIL ENCLOSURES BATTERIES SOLAR PANELS TRANSFORMERS We operate a constant improvement policy, our products are subject to change without notice. Ver 1.2 +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com 20A/500V UL=12A/300V, VDE&IMQ=20A/500V ≥3kV 6kV 110°C UL94-V0 flame retardant PA Copper alloy, NI & SN Copper alloy, NI & SN M3 steel zinc plated, 0.5Nm ø1.4mm
CTB9400/2 价格&库存
很抱歉,暂时无法提供与“CTB9400/2”相匹配的价格&库存,您可以联系我们找货
