CTBP0305/2
CTBP0305/2
    CAMDENBOSS
    CAMDENBOSS - CTBP0305/2 - Wire-To-Board Terminal Block, 3.5 mm, 2 Ways, 28 AWG, 16 AWG, 1.3 mm², Scr...
CTBP0305/2 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D SCREWLESS PLUGGABLES 002 PCB TERMINAL BLOCKS 081 TERMINAL STRIPS 3.5mm low profile vertical rising clamp terminal blocks Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 CTBP0305 • • • • • • • • • 2-12 pole interlocking 4-12 pole pre-assembled Ultra low profile Moulded in green UL94-V0 flame retardant PA Professional rising clamp terminals 0.32-1.3mm2 (28-16AWG) cable Captive screws Guided pin alignment Double interlock mechanism for increased strength • C approved US , IP68 CONNECTORS LENGTH UL=15A/300V, VDE=15A/250V CTBP0305/2 2 7mm ≥1.25kV CTBP0305/3 3 10.5mm CTBP0305/4 4 14mm CTBP0305/5 5 17.5mm 3.5(xx-1) 2.10 3.50 7.40 Dielectric strength POLES Ø1 .3 Impulse withstand voltage 2.0kV Working temperature -40°C to +105°C CTBP0305/6 6 21mm Moulding UL94-V0 flame retardant PA66 CTBP0305/7 7 24.5mm Pin/terminal Tinned, nickel plated brass CTBP0305/8 8 28mm Rising clamp Tinned, nickel plated brass CTBP0305/9 9 31.5mm Screw/torque M2 steel zinc plated, 0.2Nm CTBP0305/10 10 35mm CTBP0305/11 11 38.5mm 0.50 Recommended PCB hole size ø1.3mm 42mm Section: A-A CTBP0305/12 12 PCB layout 3.5xx A 8.50 0.35 3.75±0.3 3.50±0.3 INTERFACE MODULES AND RELAY BASES PA R T N O . 3.75 158 Rating 7.40 S P E C I F I C AT I O N 0.90 K E Y F E AT U R E S | Professional rising clamp CONNECT Ultra low profile | Double interlock mechanism 14 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 3.50 3.5(xx-1) A 2.10
CTBP0305/2 价格&库存
很抱歉,暂时无法提供与“CTBP0305/2”相匹配的价格&库存,您可以联系我们找货
