CTBP0750/3
CTBP0750/3
    CAMDENBOSS
    CAMDENBOSS - CTBP0750/3 - HIGH POW 90° RISING CLAMP TERMINAL BLOCK
CTBP0750/3 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS 5mm high power 90° rising clamp terminal blocks Product overview 081 TERMINAL STRIPS CTBP0750 • 2 and 3 pole double interlocking mechanism for increased strength • 4-12 pole solid block • Moulded in green UL94-V0 flame retardant PA66 • Professional rising clamp terminals • Cable acceptance - 0.13-3.31mm2 (26-12AWG) • Guided pin alignment • Captive screw • C , approved US , 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 Pin/terminal UL94-V0 flame retardant PA66 Tinned, nickel plated brass Rising clamp Tinned, nickel plated brass Screw/torque M3 steel zinc plated, 0.5Nm Recommended PCB hole size ø1.5mm 15mm CTBP0750/4 4 20mm CTBP0750/5 5 25mm CTBP0750/6 6 30mm CTBP0750/7 7 35mm CTBP0750/8 8 40mm CTBP0750/9 9 45mm CTBP0750/10 10 50mm CTBP0750/11 11 55mm CTBP0750/12 12 60mm PCB layout 0.60 158 5.00 3 3.10 10.50 5.30±0.3 CTBP0750/3 5.00(xx-1) 5.00 INTERFACE MODULES AND RELAY BASES A 5.0xx 0.60 18.00 Moulding 10mm 17.40 -40°C to 105°C LENGTH 2 17.40 2kV/1min Working temperature POLES CTBP0750/2 50 Impulse withstand voltage PA R T N O . 0.80 UL=20A/300V, VDE=24A/250V 1. Ø Rating 18.30 S P E C I F I C AT I O N 2.50 IP68 CONNECTORS Section: A-A A K E Y F E AT U R E S | Rising clamp terminals CONNECT High power | Double interlock mechanism +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 29
CTBP0750/3 价格&库存
很抱歉,暂时无法提供与“CTBP0750/3”相匹配的价格&库存,您可以联系我们找货
