P C B T E R M I N A L B LO C KS
S TA N D A R D
SCREWLESS
PLUGGABLES
002
PCB TERMINAL
BLOCKS
081
TERMINAL STRIPS
5mm pitch 45˚ rising clamp
terminal blocks
Product overview
095
WIRE TO BOARD
CONNECTORS
100
CIRCULAR
CONNECTORS
151
CTBP3000
2 and 3 pole interlocking
Professional rising clamp terminals
Low profile 45° mounting
Moulded in green UL94-V0 flame retardant
PA66
Cable acceptance VDE - 0.6-2.5mm2 (2210AWG
Cable acceptance UL - 0.6-1.6mm2 (2214AWG)
Guided pin alignment
approved
US ,
C
INTERFACE
MODULES AND
RELAY BASES
POLES
LENGTH
UL=15A/300V, VDE=24A/300V
CTBP3000/2
2
10mm
Insulation resistance
500M Ω/500V
CTBP3000/3
3
15mm
Withstand voltage
AC2000V/1min
CTBP3000/4
4
20mm
Contact resistance
20mΩ (max)
CTBP3000/5
5
25mm
Working temperature
-40°C to +105°C
CTBP3000/6
6
30mm
Moulding
UL94-V0 flame retardant PA66
CTBP3000/7
7
35mm
Pin/terminal
Tin plated brass
CTBP3000/8
8
40mm
Rising clamp
Brass, nickel plated
CTBP3000/9
9
45mm
Screw/torque
M2.5 steel, zinc plated 0.4Nm
CTBP3000/10
10
50mm
CTBP3000/11
11
55mm
CTBP3000/12
12
60mm
Recommended PCB
hole size
ø1.5mm
0.65
5
158
PA R T N O .
Rating
12.34
S P E C I F I C AT I O N
12.35
IP68 CONNECTORS
0.8
6
K E Y F E AT U R E S
CONNECT
45 Degree cable entry | Interlock mechanism
26
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 1
很抱歉,暂时无法提供与“CTBP3000/2”相匹配的价格&库存,您可以联系我们找货
