CTBP55VK/2
CTBP55VK/2
    CAMDENBOSS
    Conn Terminal Block F 2 POS 7.5mm Solder ST Thru-Hole 16A
CTBP55VK/2 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D PLUGGABLES SCREWLESS 002 Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS • • • • • • • • 2 and 3 pole interlocking Wire protector terminals Low profile Moulded in green UL94-V0 flame retardant PA66 Cable acceptance - 0.6-1.6mm2 (2214AWG) Guided pin alignment Anti solder wicking terminal US approved C S P E C I F I C AT I O N Rating Insulation resistance 158 INTERFACE MODULES AND RELAY BASES CTBP55VK Withstand voltage Contact resistance Working temperature Moulding Pin/terminal Wire protector Screw/torque Recommended PCB hole size PA R T N O . POLES LENGTH UL=16A/250V, VDE=24A/250V CTBP55VK/2 2 15mm 500MΩ/500V CTBP55VK/3 3 22.5mm AC2000V/1min CTBP55VK/4 4 30mm 20mΩ (max) CTBP55VK/5 5 37.5mm CTBP55VK/6 6 45mm CTBP55VK/7 7 52.5mm CTBP55VK/8 8 60mm CTBP55VK/9 9 67.5mm CTBP55VK/10 10 75mm CTBP55VK/11 11 82.5mm CTBP55VK/12 12 90mm -40°C to +105°C UL94-V0 flame retardant PA66 Tin plated brass Phosphor bronze, nickel plated M2.5 Steel, zinc plated 0.4Nm ø1.5mm 9.1 TERMINAL STRIPS 12.5 081 7. 5 m m p i t c h c o m m e r c i a l l o w p r o f i l e screw terminal blocks 4.6 PCB TERMINAL BLOCKS 5 K E Y F E AT U R E S | Wire protector terminals CONNECT Commercial value | Interlock mechanism 38 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 7.5 3.75
CTBP55VK/2 价格&库存
很抱歉,暂时无法提供与“CTBP55VK/2”相匹配的价格&库存,您可以联系我们找货
