CTBP93HD/11
CTBP93HD/11
    CAMDENBOSS
    CAMDENBOSS  CTBP93HD/11  TERMINAL BLOCK, HEADER, 11POS, R/A, TH ...
CTBP93HD/11 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D PLUGGABLES SCREWLESS 002 PCB TERMINAL BLOCKS 081 TERMINAL STRIPS 3.5mm pitch pluggable rising clamp terminal blocks Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS S P E C I F I C AT I O N • 2-12 pole solid block professional rising clamp terminals • Moulded in green UL94-V0 flame retardant PA66 • Cable acceptance - 0.32 to 1.3mm2 (28-16AWG) solid and stranded cable • Polarised mouldings • Pluggable male and female connectors • Closed headers • Horizontal and vertical female plug styles • Anti solder wicking • Captive screws • Guided pin alignment • C approved US , Rating UL=8A/300V, VDE=10A/250V Insulation resistance 500M Ω/500V Withstand voltage AC2000V/1min Contact resistance 20mΩ (max) Working temperature -40°C to +105°C Moulding UL94-V0 flame retardant PA66 Pin/terminal Tin plated brass Rising clamp Brass, nickel plated Screw/torque M2 steel, zinc plated 0.2Nm Recommended PCB hole size ø1.4mm Female connector PA R T N O . POLES LENGTH CTBP92HD/2 2 7.8mm CTBP92HD/3 3 11.3mm CTBP92HD/4 4 14.8mm CTBP92HD/5 5 18.3mm CTBP92HD/6 6 21.8mm CTBP92HD/7 7 25.3mm CTBP92HD/8 8 28.8mm CTBP92HD/9 9 32.3mm CTBP92HD/10 10 35.8mm CTBP92HD/11 11 39.3mm CTBP92HD/12 12 42.8mm CTBP92HD 16.2 3.5 6.7 2.2 INTERFACE MODULES AND RELAY BASES 11.2 158 Female vertical connector (standard) LENGTH 2 7.8mm CTBP92VD/3S 3 11.3mm CTBP92VD/4S 4 14.8mm CTBP92VD/5S 5 18.3mm CTBP92VD/6S 6 21.8mm CTBP92VD/7S 7 25.3mm CTBP92VD/8S 8 28.8mm CTBP92VD/9S 9 32.3mm CTBP92VD/10S 10 35.8mm CTBP92VD/11S 11 39.3mm CTBP92VD/12S 12 42.8mm CTBP92VD S 10.5 19.2 POLES CTBP92VD/2S 6.6 PA R T N O . 3.5 58 POLES LENGTH CTBP92VD/2R 2 7.8mm CTBP92VD/3R 3 11.3mm CTBP92VD/4R 4 14.8mm CTBP92VD/5R 5 18.3mm CTBP92VD/6R 6 21.8mm CTBP92VD/7R 7 25.3mm CTBP92VD/8R 8 28.8mm CTBP92VD/9R 9 32.3mm CTBP92VD/10R 10 35.8mm CTBP92VD/11R 11 39.3mm CTBP92VD/12R 12 42.8mm CTBP92VD R +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 10.5 19.2 PA R T N O . 6.6 CONNECT Female vertical connector (reversed) 3.5 SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS PCB mounting male horizontal connector (closed ended) 8.4mm CTBP93HD/3 3 11.9mm CTBP93HD/4 4 15.4mm CTBP93HD/5 5 18.9mm CTBP93HD/6 6 22.4mm CTBP93HD/7 7 25.9mm CTBP93HD/8 8 29.4mm CTBP93HD/9 9 32.9mm CTBP93HD/10 10 36.4mm CTBP93HD/11 11 39.9mm CTBP93HD/12 12 43.4mm CTBP93HD 081 TERMINAL STRIPS 3.5 095 WIRE TO BOARD CONNECTORS 7.2 9.2 LENGTH 2 0.8 POLES CTBP93HD/2 1.2 PA R T N O . 100 3.4 CIRCULAR CONNECTORS PCB mounting male vertical connector (closed ended) LENGTH CTBP93VD/2 2 8.4mm CTBP93VD/3 3 11.9mm CTBP93VD/4 4 15.4mm CTBP93VD/5 5 18.9mm CTBP93VD/6 6 22.4mm CTBP93VD/7 7 25.9mm CTBP93VD/8 8 29.4mm CTBP93VD/9 9 32.9mm CTBP93VD/10 10 36.4mm CTBP93VD/11 11 39.9mm CTBP93VD/12 12 43.4mm 151 IP68 CONNECTORS CTBP93VD 158 INTERFACE MODULES AND RELAY BASES 7.2 9.2 POLES 0.8 3 3.4 PA R T N O . 3.5 A S S O C I AT E D P R O D U C T S C T B 92 H D, C T B 92 V D S a n d C T B P 92 V D R c a n b e re p l a ce d w i t h a s c rew l e ss t y p e te r m i n a l block for a reduced assembly time. - page 77 CONNECT CSTBP92HD +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 59
CTBP93HD/11 价格&库存
很抱歉,暂时无法提供与“CTBP93HD/11”相匹配的价格&库存,您可以联系我们找货
