P C B T E R M I N A L B LO C KS
S TA N D A R D
PLUGGABLES
SCREWLESS
002
PCB TERMINAL
BLOCKS
081
TERMINAL STRIPS
2.5mm pitch pluggable screwless
terminal blocks
Product overview
095
WIRE TO BOARD
CONNECTORS
100
CIRCULAR
CONNECTORS
S P E C I F I C AT I O N
2-12 pole solid block
Screwless connectivity
Moulded in green UL94-V0, flame retardant PA66
Cable acceptance - 0.12mm2 - 0.5mm2 (26-20AWG)
Pluggable male and female connectors
Polarised mouldings
US approved
C
Rating
UL=4A/150V, IEC=5A/250V
Insulation resistance
500MΩ/500V
Withstand voltage
AC1250V/1min
Contact resistance
20mΩ (max)
Working temperature
-40°C to +105°C
Moulding
Spring
Stainless steel
Contact
Bronze, Ni plated
Recommended PCB hole size 1.4mm
INTERFACE
MODULES AND
RELAY BASES
PA R T N O .
POLES
LENGTH
CSTBP92HC/2
2
5.6mm
CSTBP92HC/3
3
8.1mm
CSTBP92HC/4
4
10.6mm
CSTBP92HC/5
5
13.1mm
CSTBP92HC/6
6
15.6mm
CSTBP92HC/7
7
18.1mm
CSTBP92HC/8
8
20.6mm
CSTBP92HC/9
9
23.1mm
CSTBP92HC/10
10
25.6mm
CSTBP92HC/11
11
28.1mm
CSTBP92HC/12
12
30.6mm
CSTBP92HC
3.9
5.8
158
Female connector
19.2
IP68 CONNECTORS
17.2
151
L
11.75
ᴓ1.6
1.4
Male header vertical connector
6.9mm
CTBP93VC/3
3
9.4mm
CTBP93VC/4
4
11.9mm
CTBP93VC/5
5
14.4mm
CTBP93VC/6
6
16.9mm
CTBP93VC/7
7
19.4mm
CTBP93VC/8
8
21.9mm
CTBP93VC/9
9
24.4mm
CTBP93VC/10
10
26.9mm
CTBP93VC/11
11
29.4mm
CTBP93VC/12
12
31.9mm
CTBP93VC
8.10
3.90
2.50
0.80
6.60
LENGTH
2
2.5
POLES
CTBP93VC/2
10.10
PA R T N O .
90
3
9.4mm
CTBP93HC/4
4
11.9mm
CTBP93HC/5
5
14.4mm
CTBP93HC/6
6
16.9mm
CTBP93HC/7
7
19.4mm
CTBP93HC/8
8
21.9mm
CTBP93HC/9
9
24.4mm
CTBP93HC/10
10
26.9mm
CTBP93HC/11
11
29.4mm
CTBP93HC/12
12
31.9mm
10.10
2.5(XX-1)+4.40
0.80
2.50
2.5(XX-1)
A
0.30
8.90
Section A-A
2.5(XX-1)
2.50
8.90
CTBP93HC/3
CTBP93HC
40
6.9mm
Ø1
LENGTH
2
8.90
POLES
CTBP93HC/2
8.10
*3.50+0.3
PA R T N O .
10.10
CONNECT
Male header horizontal connector
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers
Vers21
FM 28614
EMS 613558
