CTBPD96HG/10
CTBPD96HG/10
    CAMDENBOSS
    CAMDENBOSS - CTBPD96HG/10 - TERMINAL BLOCK, DIN RAIL, 10POS, 14AWG
CTBPD96HG/10 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS 5mm DIN rail mounted inverted/ reverse terminal blocks Product overview • • • • • • • • 081 TERMINAL STRIPS S P E C I F I C AT I O N Horizontal orientations Polarized moldings Can be reversed on DIN clips Also available in 5.08mm pitch Molded in green UL94-V0 flame retardant PA 66 2.5mm2 (28-14AWG) approved US , C 6-12 poles standard (13-24 also available) Rating UL=15A/300V IEC 20A/450V Insulation resistance 500MΩ/500V Withstand Voltage AC2000V/1min Contact Resistance 20mΩ (max) Working Temperature -40°C to 105+°C Mouldings UL94-V0 Flame retardant PA66 Pin/Terminal Brass, Tin plated Rising Clamp Brass, nickel plated Screw/Torque M3 Steel, zinc plated 0.5Nm 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS DIN rail mounting male horizontal LENGTH 6 31.4mm CTBPD96HG/7 7 36.4mm CTBPD96HG/8 8 41.4mm CTBPD96HG/9 9 46.4mm CTBPD96HG/10 10 51.4mm CTBPD96HG/11 11 56.4mm CTBPD96HG/12 12 61.4mm CTBPD96HG 31.4 5 19.2 1 20 POLES CTBPD96HG/6 158 20.2 32.6 PA R T N O . INTERFACE MODULES AND RELAY BASES 12.3 42.5 11.6 8.4 11.6 19.2 DIN rail mounting male horizontal flanged LENGTH A LENGTH B 31.4mm 40.0mm CTBPD96HG/7FL 7 36.4mm 45.0mm CTBPD96HG/8FL 8 41.4mm 50.0mm CTBPD96HG/9FL 9 46.4mm 55.0mm CTBPD96HG/10FL 10 51.4mm 60.0mm CTBPD96HG/11FL 11 56.4mm 65.0mm CTBPD96HG/12FL 12 61.4mm 70.0mm CTBPD96HG/FL 5 Length B Length A 19.2 5 1 20.2 12.3 42.5 11.6 8.4 11.6 19.2 CONNECT POLES 6 20 32.6 PA R T N O . CTBPD96HG/6FL +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 65
CTBPD96HG/10 价格&库存
很抱歉,暂时无法提供与“CTBPD96HG/10”相匹配的价格&库存,您可以联系我们找货
