FT094-509
FT094-509
    CAMDENBOSS
FT094-509 数据手册
M E TA L E N C L O S U R E S 408 METAL ENCLOSURES 5000 Series Multipurpose Diecast 423 UNIVERSAL METAL ENCLOSURES Product overview RTM5001 Highly durable robust aluminium diecast boxes with RFI shielding properties. • Diecast aluminium • Lid mounted by M3 machine screws • Temperature resistant up to 260°C (without gasket) • Highly durable and shock resistant • Vertical guides for PCB fixing • Optional neoprene gasket for IP65 seal • Enclosure screws can be used with the wall mount kit • 5000 series has been designed to meet the requirements of IP54 or additionally, IP65* with the gasket accessory (*excluding the RTM5007) S P E C I F I C AT I O N Lid and base diecast aluminium to ENAC 44200 Protection class 5000 series has been designed to meet the requirements of IP54 or additionally, IP65* with the gasket accessory (*excluding the RTM5007) Standard colours Black RAL 9005, white RAL 9016, natural, hammertone, red RAL 3020, yellow RAL 1023, blue RAL 5005 and green RAL 6001 Standard unit includes Base, lid and, zinc plated M3 screw Options Wall mounting kit IP65 gasket H W N AT U R A L HAMMERTONE B L AC K WHITE LENGTH W I DT H HEIGHT RTM5001/11-NAT RTM5001/11-PAT RTM5001/11-BLK RTM5001/11-WH 50mm 50mm 31mm RTM5002/12-NAT RTM5002/12-PAT RTM5002/12-BLK RTM5002/12-WH 101mm 50mm 25mm RTM5003/13-NAT RTM5003/13-PAT RTM5003/13-BLK RTM5003/13-WH 112mm 62mm 31mm RTM5004/14-NAT RTM5004/14-PAT RTM5004/14-BLK RTM5004/14-WH 120mm 66mm 40mm RTM5005/15-NAT RTM5005/15-PAT RTM5005/15-BLK RTM5005/15-WH 152mm 82mm 50mm RTM5006/16-NAT RTM5006/16-PAT RTM5006/16-BLK RTM5006/16-WH 192mm 112mm 61mm RTM5007/17-NAT RTM5007/17-PAT RTM5007/17-BLK RTM5007/17-WH 121mm 95mm 61mm RED Y E L LOW BLUE GREEN LENGTH W I DT H HEIGHT RTM5001/11-RED RTM5001/11-YEL RTM5001/11-BLU RTM5001/11-GRN 50mm 50mm 31mm RTM5002/12-RED RTM5002/12-YEL RTM5002/12-BLU RTM5002/12-GRN 101mm 50mm 25mm RTM5003/13-RED RTM5003/13-YEL RTM5003/13-BLU RTM5003/13-GRN 112mm 62mm 31mm RTM5004/14-RED RTM5004/14-YEL RTM5004/14-BLU RTM5004/14-GRN 120mm 66mm 40mm RTM5005/15-RED RTM5005/15-YEL RTM5005/15-BLU RTM5005/15-GRN 152mm 82mm 50mm RTM5006/16-RED RTM5006/16-YEL RTM5006/16-BLU RTM5006/16-GRN 192mm 112mm 61mm RTM5007/17-RED RTM5007/17-YEL RTM5007/17-BLU RTM5007/17-GRN 121mm 95mm 61mm L M E TA L E N C L O S U R E S Materials K E Y F E AT U R E S Highly durable | RFI shielding properties | Shock resistant +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 2 FM 28614 Vers Vers21 411
FT094-509 价格&库存
很抱歉,暂时无法提供与“FT094-509”相匹配的价格&库存,您可以联系我们找货
FT094-509
  • 1+21.60872
库存:16
