CCA1P1/A04
CCA1P1/A04
    CAMDENBOSS
    CAMDENBOSS - CCA1P1/A04 - Circular Connector, IP68, Shielded, CamCirc CCA Series, Cable Mount Plug, ...
CCA1P1/A04 数据手册
ACC E SS O R I E S SOCKETS PLUGS CIRCULAR CONNECTORS 002 PCB TERMINAL DIECAST DIECAST BLOCKS ACCESSORIES ACCESSORIES Push-pull connectors cable mounted plug CCA1 series C C A 1 P 1 /A 0 4 4 pole CCA1P1/A04 • Premium range of circular connectors • IP68 sealed using vacuum technology (when connected and using environmental cable clamp) • Tough, high performance interconnection solution • Ideal for harsh and extreme environments • Suitable for broadcasting, autosport, military, rail, marine, security, industrial and agricultural applications • Key coded to prevent misconnection • Will not disconnect when the cable is under load or stress • Tested to IEC 60512-3-5a S P E C I F I C AT I O N PA R T N O . DESCRIPTION POLES SERIES CCA1P1/A04 Cable mounted plug 4 CCA series ~36 Ø5.2 9.3 ~26 7 081 TERMINAL STRIPS Shell style/model Cable mounted straight plug, male contact Codes Code 1 Contact type Solder type Contact diameter 0.7mm Max. stranded conductor AWG 21-22 Max diameter 0.79mm Vtest (contact-shell) 1200V(AC) 1800V(DC) Vtest (contact-contact) 1200V(AC) 1600V(DC) Rated current 5.5A Rated voltage ≤200V Mechanical operation 5000 mating cycles Housing material Brass (natural chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces Insulator PPS Contacts Brass (gold plated) Humidity (max) 72 hr Climatical category 50/175/21 Shielding (min) 75 dB (10 MHz) Shielding (min) 40 dB (1 GHz) IP rating IP68 (when connected and using environmental cable clamp) 8 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS 158 INTERFACE MODULES AND RELAY BASES This product should be used with the following cable clamps: PA R T N O . WIRE RANGE CCV1C/CC 2.6 - 3.1mm CCV1C/CD 3.1-3.6mm CCV1C/CE 3.6-4.1mm CCV1C/CF 4.1-4.3mm 1 Non IP68 cable clamps also available ACC E SS O R I E S Metal cap for plugs PA R T N O . DESCRIPTION CCA12 Camcirc metal cap for plug A1 C C B 1 S 1 / 0 4 C C S 1 S 1 / 0 4 - C C B s e r i e s A 1 s i z e s o c k e t - C C S s e r i e s A 1 s i z e s o c k e t CONNECT A S S O C I AT E D P R O D U C T S page 132 page 145 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 Vers 1 103
CCA1P1/A04 价格&库存
很抱歉,暂时无法提供与“CCA1P1/A04”相匹配的价格&库存,您可以联系我们找货
CCA1P1/A04
    • 1+170.05796
    • 5+166.66305
    库存:13
