H E AV Y D U T Y A N D E L E C T R I C A L E N C L O S U R E S
268
HANDHELD
CASES
DIECAST
DIECAST
ACCESSORIES
ACCESSORIES
X6 series electrical knockout
enclosures - polycarbonate
Product overview
292
UNIVERSAL
ENCLOSURES
CHDX6
• Screw type lid with knockouts on the base
• Moulded in high quality polycarbonate
• Pillars in the base can be used for PCB
mounting or DIN rail mounting, etc.
• Gasket moulded into the enclosure lid
• Clear lid option available
• Captive, polyamide lid screws included
• Larger sizes include two brass inserts at either
end of the base, suitable for DIN rails
• Wall mounting accessories available
• X6 series meets the requirements of IP67
(equivalent to NEMA 6)
• IK08 impact tested
318
HEAVY DUTY
AND ELECTRICAL
ENCLOSURES
342
DESKTOP AND
INSTRUMENT
CASES
348
DEVELOPMENT
BOARD
ENCLOSURES
S P E C I F I C AT I O N
Materials
Polycarbonate UL94-V0
Operating temperature
-40°C to + 110°C
Protection class
X6 series has been tested and
meets the requirements of IP67,
IK08
Standard colours
Grey, transparent lid option
Standard unit includes
Box, lid, 4 screws
Available accessories
Mount plates and wall mounts
367
VERSATILE IOT
AND SENSOR
ENCLOSURES
370
CUSTOM SIZED
ENCLOSURES
SOLID LID
CLEAR LID
LENGTH
W I DT H
HEIGHT
CHDX6-221
CHDX6-221C
110mm
80mm
70mm
CHDX6-222
CHDX6-222C
110mm
80mm
85mm
CHDX6-223
CHDX6-223C
130mm
80mm
70mm
CHDX6-224
CHDX6-224C
130mm
80mm
85mm
CHDX6-225
CHDX6-225C
180mm
80mm
70mm
CHDX6-226
CHDX6-226C
180mm
80mm
85mm
CHDX6-227
CHDX6-227C
250mm
80mm
70mm
CHDX6-228
CHDX6-228C
250mm
80mm
85mm
CHDX6-229
CHDX6-229C
175mm
127mm
75mm
CHDX6-230
CHDX6-230C
175mm
127mm
100mm
K E Y F E AT U R E S
P L AST I C E N C LOS U R E S
I P 6 7 r a t e d e n c l o s u r e | I K 0 7/ 0 8 i m p a c t t e s t e d | M e t r i c s i z e d k n o c k o u t s
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
FM 28614
Vers
Vers41
321
268
HANDHELD
DIECASTCASES
ACCESSORIES
292
UNIVERSAL
ENCLOSURES
enclosures - ABS
Product overview
318
HEAVY DUTY
AND ELECTRICAL
ENCLOSURES
342
DESKTOP AND
INSTRUMENT
CASES
348
DEVELOPMENT
BOARD
ENCLOSURES
CHDX6
• Moulded in high quality ABS
367
VERSATILE IOT
AND SENSOR
ENCLOSURES
370
CUSTOM SIZED
ENCLOSURES
Materials
ABS UL94-HB
-40°C- to + 70°C
Protection class
IK08
Standard colours
Box, lid, 4 screws
SOLID LID
CLEAR LID
LENGTH
W I DT H
HEIGHT
CHDX6-321
CHDX6-321C
110mm
80mm
70mm
CHDX6-322
CHDX6-322C
110mm
80mm
85mm
CHDX6-323
CHDX6-323C
130mm
80mm
70mm
CHDX6-324
CHDX6-324C
130mm
80mm
85mm
CHDX6-325
CHDX6-325C
180mm
80mm
70mm
CHDX6-326
CHDX6-326C
180mm
80mm
85mm
CHDX6-327
CHDX6-327C
250mm
80mm
70mm
CHDX6-328
CHDX6-328C
250mm
80mm
85mm
CHDX6-329
CHDX6-329C
175mm
127mm
75mm
CHDX6-330
CHDX6-330C
175mm
127mm
100mm
H i g h q u a l i t y A B S | I P 6 7 r a t e d e n c l o s u r e | I K 0 7/ 0 8 i m p a c t t e s t e d
322
Vers 4
1
FM 28614
268
HANDHELD
CASES
DIECAST
DIECAST
ACCESSORIES
ACCESSORIES
ACC E SS O R I E S
Ve n t s t o f i t X 6 , X 7
and X8 enclosures
292
• Vents in two sizes for heat
extraction
• The vent includes a gasket for
water resistant applications
• Designed to meet the
requirements of IP34
PA R T N O .
CUTOUT DIAMETER
M AT E R I A L
CHDA201V
63
Polycarbonate
CHDA202V
88
Polycarbonate
CHDA301V
63
ABS
CHDA302V
88
ABS
UNIVERSAL
ENCLOSURES
318
HEAVY DUTY
AND ELECTRICAL
ENCLOSURES
342
DESKTOP AND
INSTRUMENT
CASES
Mounting brackets
to fit X6, X7 and
X8 enclosures
• Brackets to mount each
enclosure to any surface/wall
• See cross reference page 328
to select the correct size for
your enclosure
PA R T N O .
SIZE
CHDAPB014/4
1
Size 1 Bracket, 4x12 S/T Screw, 4pc kit
CHDAPB015/4
1
Size 1 Bracket, 5x12 S/T Screw, 4pc kit
CHDAPB025/4
2
Size 2 Bracket, M5x12 Screw, 4pc kit
CHDAPB025/6
2
Size 2 Bracket, M5x12 Screw, 6pc kit
CHDAPB026/6
2
Size 2 Bracket, M6x12 Screw, 6pc kit
348
DEVELOPMENT
BOARD
ENCLOSURES
367
VERSATILE IOT
AND SENSOR
ENCLOSURES
370
CUSTOM SIZED
ENCLOSURES
Mounting plates to fit X6, X7
and X8 enclosures
• Material: Steel
• Mounting plates for each enclosure available
PA R T N O .
L E N G T H mm
W I DT H
CHDASMP21
65mm
95mm
CHDASMP22
65mm
115mm
CHDASMP23
65mm
165mm
CHDASMP24
65mm
235mm
CHDASMP25
101mm
161mm
CHDASMP26
159mm
159mm
CHDASMP27
159mm
248mm
CHDASMP28
248mm
348mm
CHDASMP29
295mm
395mm
CHDASMP30
85mm
232mm
CHDASMP32
129mm
179mm
CHDASMP33
129mm
224mm
CHDASMP34
170mm
266mm
CHDASMP35
179mm
179mm
CHDASMP36
216mm
316mm
CHDASMP37
262mm
262mm
CHDASMP38
265mm
365mm
CHDASMP39
358mm
458mm
CHDASMP40
450mm
555mm
CHDASMP41
550mm
755mm
CHDASMP42
248mm
248mm
CHDASMP43
248mm
308mm
CHDASMP44
232mm
535mm
CHDASMP45
345mm
535mm
CHDASMP46
159mm
348mm
CHDASMP49
65mm
65mm
• See cross reference page 329 to select the
correct size for your enclosure
FM 28614
Vers 12
Vers
327
268
HANDHELD
DIECASTCASES
ACCESSORIES
292
UNIVERSAL
ENCLOSURES
318
HEAVY DUTY
AND ELECTRICAL
ENCLOSURES
ACC E SS O R I E S
Dual door to fit the
X8 enclosure
PA R T N O .
KIT INCLUDES
CHDX807DD
4 legs, 1 door, 1 door handle, 1 frame, 8 screws
• Easy to assemble, sturdy
construction
CHDX808DD
your enclosure
CHDX810DD
CHDX811DD
CHDX812DD
CHDX813DD
CHDX814DD
• Dual door avaliable for some
sizes
342
DESKTOP AND
INSTRUMENT
CASES
348
DEVELOPMENT
BOARD
ENCLOSURES
367
VERSATILE IOT
AND SENSOR
ENCLOSURES
Lock to fit the X8
enclosure
• One or two locks can be fitted,
depending on security level
required
your enclosure
polycarbonate
PA R T N O .
SIZE
CHDA01IL
1
CHDA02IL
2
CHDA03IL
3
CHDA04IL
4
370
CUSTOM SIZED
ENCLOSURES
328
Vers 1
FM 28614
268
HANDHELD
CASES
DIECAST
DIECAST
ACCESSORIES
ACCESSORIES
ACC E SS O R I E S F O R X 6 , X 7 A N D X 8 S E R I E S
C H DX 8 1 4 D D
C H DX 8 1 3 D D
C H DX 8 1 2 D D
292
C H DX 8 1 1 D D
C H DX 8 0 1 0 D D
C H DX 8 0 8 D D
C H DX 8 0 7 D D
C H DA 0 4 I L
DUAL DOOR
C H DA 0 3 I L
C H DA 0 2 I L
C H DA 0 1 I L
C H DA P B 0 2 6 / 6
LO C KS
C H DA P B 0 2 5 / 6
C H DA P B 0 2 5 /4
UNIVERSAL
ENCLOSURES
318
HEAVY DUTY
AND ELECTRICAL
ENCLOSURES
CHDX6-221
CHDX6-321
CHDX6-222
CHDX6-322
CHDX6-223
CHDX6-323
CHDX6-224
CHDX6-324
CHDX6-225
CHDX6-325
CHDX6-226
CHDX6-326
CHDX6-227
CHDX6-327
CHDX6-228
CHDX6-328
CHDX6-229
CHDX6-329
CHDX6-230
CHDX6-330
CHDX7-221
CHDX7-321
CHDX7-222
CHDX7-322
CHDX7-223
CHDX7-323
CHDX7-224
CHDX7-324
CHDX7-225
CHDX7-325
CHDX7-226
CHDX7-326
CHDX7-227
CHDX7-327
CHDX7-228
CHDX7-328
CHDX7-229
CHDX7-329
CHDX7-230
CHDX7-330
CHDX7-231
CHDX7-331
CHDX7-232
CHDX7-332
CHDX7-237
CHDX7-327
CHDX8-221
CHDX8-321
CHDX8-222
CHDX8-322
CHDX8-223
CHDX8-333
CHDX8-224
CHDX8-324
CHDX8-225
CHDX8-325
CHDX8-226
CHDX8-326
CHDX8-227
CHDX8-327
CHDX8-228
CHDX8-328
CHDX8-229
CHDX8-329
CHDX8-230
CHDX8-330
CHDX8-231
CHDX8-331
CHDX8-232
CHDX8-332
CHDX8-233
CHDX8-333
CHDX8-234
CHDX8-334
CHDX8-235
CHDX8-335
CHDX8-236
CHDX8-336
342
DESKTOP AND
INSTRUMENT
CASES
348
DEVELOPMENT
BOARD
ENCLOSURES
367
VERSATILE IOT
AND SENSOR
ENCLOSURES
370
CUSTOM SIZED
ENCLOSURES
ABS
C H DA P B 0 1 5 /4
P O LY
W/ M O U N T
C H DA P B 0 1 4 /4
E N C L O S U R E PA R T N O .
*Add 'c' suffix for clear lid versions
FM 28614
1
Vers 2
329
268
HANDHELD
DIECASTCASES
ACCESSORIES
M O U N T I N G P L AT E S
318
HEAVY DUTY
AND ELECTRICAL
ENCLOSURES
342
DESKTOP AND
INSTRUMENT
CASES
348
DEVELOPMENT
BOARD
ENCLOSURES
CHDX7-229
CHDX7-329
CHDX7-230
CHDX7-330
367
VERSATILE IOT
AND SENSOR
ENCLOSURES
CHDX7-231
CHDX7-331
CHDX7-232
CHDX7-332
CHDX8-221
CHDX8-321
370
CHDX8-222
CHDX8-322
CUSTOM SIZED
ENCLOSURES
CHDX8-223
CHDX8-323
CHDX8-224
CHDX8-324
CHDX8-225
CHDX8-325
CHDX8-226
CHDX8-326
CHDX8-227
CHDX8-327
CHDX8-228
CHDX8-328
CHDX8-229
CHDX8-329
CHDX8-230
CHDX8-330
CHDX8-231
CHDX8-331
CHDX8-232
CHDX8-332
CHDX8-233
CHDX8-333
CHDX8-234
CHDX8-334
CHDX8-235
CHDX8-335
CHDX8-236
CHDX8-336
C H DA S M P 4 6
CHDX7-328
C H DA S M P 4 5
CHDX7-228
C H DA S M P 4 4
CHDX7-327
C H DA S M P 4 3
CHDX7-227
C H DA S M P 4 2
CHDX7-326
C H DA S M P 4 1
CHDX7-226
C H DA S M P 4 0
CHDX7-325
C H DA S M P 3 9
CHDX7-324
CHDX7-225
C H DA S M P 3 8
CHDX7-224
C H DA S M P 3 7
C H DA S M P 3 6
CHDX7-323
C H DA S M P 3 5
CHDX7-223
C H DA S M P 3 4
CHDX7-322
C H DA S M P 3 3
CHDX7-222
C H DA S M P 3 2
CHDX7-321
C H DA S M P 3 1
CHDX7-221
C H DA S M P 3 0
CHDX6-330
C H DA S M P 2 9
CHDX6-230
C H DA S M P 2 8
CHDX6-329
UNIVERSAL
ENCLOSURES
C H DA S M P 2 7
CHDX6-229
292
C H DA S M P 2 6
ABS
C H DA S M P 2 5
P O LY
330
Vers 2
1
FM 28614
