CIME/M/SE2250SS
CIME/M/SE2250SS
    CAMDENBOSS
CIME/M/SE2250SS 数据手册
I N T E R FA C E M O D U L E S & R E L AY B A S E S I N T E R FA C E M O D U L E S R E L AY B A S E S 002 PCB TERMINAL DIECAST BLOCKS ACCESSORIES 081 TERMINAL STRIPS Mini series 72mm empty modular interface supports Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS • S  uitable for 72mm width PCB’s • Modular construction for easy Assembly • Snap fit DIN Rail mounting fixtures • Moulded in grey UL94-V0 flame retardant PA6 • Wall mounting kit option • Terminal blocks available in same colour • Integral marker facility • Registered design No: 2106418® • Also available in different colours • End section foot for top hat DIN Rail Wa l l m o u n t p l a t e s 1INTERFACE 58 MODULES AND RELAY BASES • Flush and raised surface mounting plates • Press into sides of end section without tool • Use foot element on long lengths with raised plates PA R T N O . DESCRIPTION CIME/M/MPF Flush CIME/M/MPR Raised CIME/M CIME/M/ T O TA L P C B LENGTH END SECTION SEF1125SS 10MM 20mm 2 31.25mm 1 SEF2250SS 21.25MM DESCRIPTION W I DT H CIME/M/BE1125SS Base element 11.25mm CIME/M/BE2250SS Base element 22.5mm CIME/M/BE4500SS Base element 45.0mm CIME/M/SE1125SS End section 11.25mm CIME/M/SE2250SS End section 22.5mm CIME/M/SEF1125S End section with foot 11.25mm CIME/M/SEF2250S End section with foot 22.5mm CIME/M/FE0000SS Foot element BASE ELEMENTS BE1125SS 11.25MM 53.75mm 2 2 1 3 1 1 3 87.5mm 2 1 3 98.75mm 2 1 4 110mm 2 1 4 1 2 4 132.5mm 2 2 4 143.75mm 2 2 5 155mm 2 2 5 1 3 5 2 3 5 121.25mm 1 1 177.5mm 1 1 1 1 Base element Foot element 22.50 45 A B C End section End section with foot 11.20 22.20 D E 4 11.20 22.20 F G CONNECT 72.40 15.80 20 18.68 59.65 11.25 72.40 15.80 3 1 166.25mm 4 PA R T C O U N T 2 2 1 BE4500SS 45MM 1 2 76.25mm BE2250SS 22.5MM 2 42.5mm 65mm PA R T N O . 161 4 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614
CIME/M/SE2250SS 价格&库存
很抱歉,暂时无法提供与“CIME/M/SE2250SS”相匹配的价格&库存,您可以联系我们找货
CIME/M/SE2250SS
    • 1+12.638301+1.63976
