CTB0112/2
CTB0112/2
    CAMDENBOSS
    7.5mm Rising Clamp Terminal 2 Way
CTB0112/2 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D PLUGGABLES SCREWLESS ECONOMY RANGE 7. 5 m m p i t c h s t a n d a r d p r o f i l e r i s i n g clamp terminal blocks Product overview CTB0112 • 2 & 3 pole double interlocking mechanism for increased strength • 4-12 solid block end stackable • Moulded in green UL94-V0 flame retardant PA66 • Professional rising clamp terminals • 0.33-3.3 mm2 (22-12 AWG) • Guided pin alignment • Captive screws • approved POLES LENGTH 10A 300V CTB0112/2 2 15mm Insulation resistance 5000M Ω/1000V CTB0112/3 3 22.5mm Withstand voltage AC1500V/1min CTB0112/4 4 30mm Contact resistance 20m Ω CTB0112/5 5 37.5mm Working temperature -33°C to +120°C CTB0112/6 6 45mm Moulding UL94-V0 flame retardant PA66 CTB0112/7 7 52.5mm Pin/terminal Tin plated brass CTB0112/8 8 60mm Rising clamp Nickel plated brass CTB0112/9 9 67.5mm Screw/torque M2.5 steel, nickel pated 0.4Nm CTB0112/10 10 75mm Recommended PCB hole size ø1.5mm CTB0112/11 11 82.5mm CTB0112/12 12 90mm 0.6 15.0±0.05 2.5x2.5 10.3 7.5±0.05 0.9 0.8 4.0±0.2 PA R T N O . Rating 14.3 S P E C I F I C AT I O N 5.0 K E Y F E AT U R E S E CO N O M Y R A N G E P C B T E R M I N A L B LO C KS P r o f e s s i o n a l r i s i n g c l a m p s | U L 9 4 -V 0 PA m o u l d i n g | I n t e r l o c k i n g 11 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614 EMS 613558
CTB0112/2 价格&库存
很抱歉,暂时无法提供与“CTB0112/2”相匹配的价格&库存,您可以联系我们找货
