CTB0508/10
CTB0508/10
    CAMDENBOSS
CTB0508/10 数据手册
PCB TERMINAL BLOCKS PCB TERMINAL BLOCKS INTERCONNECTION FUSES & FUSEHOLDERS LEDs & INDICATORS MINIATURE SWITCHES LIMIT & SAFETY SWITCHES CONTROL PRODUCTS 5.08mm Pitch Low Profile Rising Clamp Terminal Blocks • 2 & 3 pole double interlocking mechanism for increased strength • 4 -12 solid block end stackable • Moulded in green UL94-V0 flame retardant PA66 • Professional rising clamp terminals • 0.2-2.5mm2 (30-14AWG) solid cable • 0.2-1.5mm2 (30-14AWG) stranded cable • Guided pin alignment • Captive screw • , , approved SPECIFICATION Rating CTB0508 Dielectric strength Impulse withstand voltage Working temperature Moulding Pin/terminal Rising clamp Screw/torque Recommended PCB hole size TYPE NO. CTB0508/2 CTB0508/3 CTB0508/4 CTB0508/5 CTB0508/6 CTB0508/7 CTB0508/8 CTB0508/9 CTB0508/10 CTB0508/11 CTB0508/12 POLES 2 3 4 5 6 7 8 9 10 11 12 14A/250V UL=14A/300V, VDE&IMQ=14A/250V ≥2kV 4kV 110°C UL94-V0 flame retardant PA66 Tinned, nickel plated brass Tinned, nickel plated brass M3 steel zinc plated, 0.5Nm ø1.3mm LENGTH 10.16mm 15.24mm 20.32mm 25.4mm 30.48mm 35.56mm 40.64mm 45.72mm 50.8mm 55.88mm 60.96mm INTERFACE MODULES & SUPPORTS RELAY BASES DIN RAIL ENCLOSURES BATTERIES SOLAR PANELS TRANSFORMERS We operate a constant improvement policy, our products are subject to change without notice. Ver 1.1 +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com
CTB0508/10 价格&库存
很抱歉,暂时无法提供与“CTB0508/10”相匹配的价格&库存,您可以联系我们找货
