PCB TERMINAL BLOCKS
5.08mm Pitch High Power Rising Clamp Terminal Blocks
• 2 & 3 pole double
interlocking mechanism for
increased strength
• 4-12 pole solid block
• Moulded in green UL94-V0
flame retardant PA66
• Professional rising
clamp terminals
• 0.2-4.0mm2 (30-12AWG)
solid cable
• 0.2-2.5mm2 (30-12AWG)
stranded cable
• Guided pin alignment
• Captive screw
approved
SPECIFICATION
Rating
CTB0708
Dielectric strength
Impulse withstand voltage
Working temperature
Moulding
Pin/terminal
Rising clamp
Screw/torque
Recommended PCB hole size
PCB
TERMINAL
BLOCKS
24A/320V
UL=16A/300V, VDE&IMQ=24A/450V
≥2.5kV
4kV
110°C
UL94-V0 flame retardant PA66
Tinned, nickel plated brass
M3 steel zinc plated, 0.5Nm
ø1.5mm
INTERCONNECTION
FUSES &
FUSEHOLDERS
LEDs &
INDICATORS
TYPE NO.
CTB0708/2
CTB0708/3
CTB0708/4
CTB0708/5
CTB0708/6
CTB0708/7
CTB0708/8
CTB0708/9
CTB0708/10
CTB0708/11
CTB0708/12
POLES
2
3
4
5
6
7
8
9
10
11
12
LENGTH
10.16mm
15.24mm
20.32mm
25.4mm
30.48mm
35.56mm
40.64mm
45.72mm
50.8mm
55.88mm
60.96mm
MINIATURE
SWITCHES
LIMIT &
SAFETY
SWITCHES
CONTROL
PRODUCTS
INTERFACE
MODULES &
SUPPORTS
RELAY
BASES
DIN RAIL
ENCLOSURES
BATTERIES
SOLAR
PANELS
TRANSFORMERS
+44 (0)1638 716101
info@camdenboss.com
www.camdenboss.com
We operate a constant improvement
policy, our products are subject to
change without notice.
Ver 1.1
很抱歉,暂时无法提供与“CTB0708/8”相匹配的价格&库存,您可以联系我们找货
