CTB7000/36
CTB7000/36
    CAMDENBOSS
CTB7000/36 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS 5mm pitch 36 pole rising clamp terminal blocks Product overview S P E C I F I C AT I O N Rating Dielectric strength Impulse withstand voltage Working temperature PA R T N O . POLES LENGTH 22A/250V UL=16A/300V, VDE and IMQ=22A/450V CTB7000/1 1 5mm CTB7000/2 2 10mm ≥2.5kV CTB7000/3 3 15mm 4kV CTB7000/4 4 20mm 85°C CTB7000/5 5 25mm CTB7000/6 6 30mm CTB7000/7 7 35mm CTB7000/8 8 40mm CTB7000/9 9 45mm CTB7000/10 10 50mm CTB7000/11 11 55mm CTB7000/12 12 60mm CTB7000/18 18 90mm CTB7000/36 36 180mm Moulding UL94-V0 flame retardant PC Pin/terminal Tinned, nickel plated brass Rising clamp Nickel plated brass Screw/torque Recommended PCB hole size 151 IP68 CONNECTORS M2.5 steel zinc plated, 0.5Nm ø1.3mm 2.9x3 • • • 100 CIRCULAR CONNECTORS INTERFACE MODULES AND RELAY BASES 0.7 1 2.5 158 8.5 • 095 WIRE TO BOARD CONNECTORS 15.5 • CTB7000 Unique 36 pole strips Professional rising clamp terminals Standard profile Moulded in grey UL94-V0 flame retardant PC Cable acceptance - 0.2-2mm2 (30-12AWG) solid cable Cable acceptance - 0.2-2mm2 (30-12AWG) stranded cable Easily cut to required number of poles or can be supplied pre-cut Guided pin alignment Anti solder wicking , approved US , C 4.5 • • • • • 081 TERMINAL STRIPS 5 2.5 4.25 5 K E Y F E AT U R E S | Unique 36 pole design CONNECT Professional rising clamp | Easily cut to required size +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 25
CTB7000/36 价格&库存
很抱歉,暂时无法提供与“CTB7000/36”相匹配的价格&库存,您可以联系我们找货
CTB7000/36
  • 1+99.04601
  • 75+97.07779
  • 400+93.58916
库存:35
