CTB7300/36F
CTB7300/36F
    CAMDENBOSS
CTB7300/36F 数据手册
PCB TERMINAL BLOCKS 5mm Pitch Pluggable for Vertical or 90˚ mounting Rising Clamp Terminal • Unique 36 pole strip • Easily cut to required number of poles • Can be supplied pre-cut to specified number of poles • Dual horizontal or vertical mounting • Moulded in grey UL94-V0 flame retardant PC • Professional rising clamp terminals • 0.2-2.5mm2 (24-12AWG) solid & stranded cable • Optional polarising clips • Anti solder wicking • Guided pin alignment • Captive screws • , ,approved SPECIFICATION Rating Dielectric strength Impule withstand voltage Working temperature Moulding Pin/terminal Rising clamp Screw/torque Recommended PCB hole size 16A/250V UL=14A/300V, VDE&IMQ=16A/250V ≥2.5kV 4kV 130°C UL94-V0 flame retardant PC Tinned, nickel plated brass Zinc plated steel M2.5 steel zinc plated, 0.4Nm ø1.3mm PCB TERMINAL BLOCKS INTERCONNECTION FUSES & FUSEHOLDERS LEDs & INDICATORS Female connector TYPE NO. CTB7300/2F CTB7300/3F CTB7300/4F CTB7300/5F CTB7300/6F CTB7300/7F CTB7300/8F CTB7300/9F CTB7300/10F CTB7300/11F CTB7300/12F CTB7300/36F POLES 2 3 4 5 6 7 8 9 10 11 12 36 LENGTH 10mm 15mm 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm 180mm MINIATURE SWITCHES CTB7300/F LIMIT & SAFETY SWITCHES CONTROL PRODUCTS INTERFACE MODULES & SUPPORTS PCB mounting male TYPE NO. CTB7300/2M CTB7300/3M CTB7300/4M CTB7300/5M CTB7300/6M CTB7300/7M CTB7300/8M CTB7300/9M CTB7300/10M CTB7300/11M CTB7300/12M CTB7300/36M POLES 2 3 4 5 6 7 8 9 10 11 12 36 LENGTH 10mm 15mm 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm 180mm CTB7300/M RELAY BASES DIN RAIL ENCLOSURES BATTERIES Polarising Clip TYPE NO. CTB7300C 1 pair Fitted to each end of the male connector ensures correct vertical or horizontal orientation of the female part CTB7300/C SOLAR PANELS TRANSFORMERS +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Ver 1.1
CTB7300/36F 价格&库存
很抱歉,暂时无法提供与“CTB7300/36F”相匹配的价格&库存,您可以联系我们找货
