CTB92VG/12S
CTB92VG/12S
    CAMDENBOSS
CTB92VG/12S 数据手册
PCB TERMINAL BLOCKS PCB TERMINAL BLOCKS INTERCONNECTION FUSES & FUSEHOLDERS 5mm Pitch Pluggable Rising Clamp Terminal Blocks • 2-24 pole solid block • Pluggable male-female connectors • Open & closed headers • Horizontal & vertical female plug styles • Polarised mouldings • Moulded in green UL94-V0 flame retardant PA • Professional rising clamp terminals • 0.2-2.5mm2 (30-12AWG) solid & stranded cable • Anti solder wicking • Captive screws • Guided pin alignment • , , approved SPECIFICATION Rating Dielectric strength Impulse withstand voltage Working temperature Moulding Pin/terminal Rising clamp Screw/torque Recommended PCB hole size 20A/320V UL=12A/300V, VDE&IMQ=20A/320V ≥2.5kV 4kV 100°C UL94-V0 flame retardant PA Copper alloy, NI & SN Copper alloy, NI & SN M3 steel zinc plated, 0.5Nm ø1.4mm LEDs & INDICATORS CTB92VG/S Female connector vertical (standard) MINIATURE SWITCHES LIMIT & SAFETY SWITCHES CONTROL PRODUCTS TYPE NO. CTB92VG/2S CTB92VG/3S CTB92VG/4S CTB92VG/5S CTB92VG/6S CTB92VG/7S CTB92VG/8S CTB92VG/9S CTB92VG/10S CTB92VG/11S CTB92VG/12S CTB92VG/13S POLES 2 3 4 5 6 7 8 9 10 11 12 13 LENGTH 10mm 15mm 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm 65mm TYPE NO. CTB92VG/14S CTB92VG/15S CTB92VG/16S CTB92VG/17S CTB92VG/18S CTB92VG/19S CTB92VG/20S CTB92VG/21S CTB92VG/22S CTB92VG/23S CTB92VG/24S POLES 14 15 16 17 18 19 20 21 22 23 24 LENGTH 70mm 75mm 80mm 85mm 90mm 95mm 100mm 105mm 110mm 115mm 120mm INTERFACE MODULES & SUPPORTS Female connector vertical (reversed) RELAY BASES DIN RAIL ENCLOSURES BATTERIES TYPE NO. CTB92VG/2R CTB92VG/3R CTB92VG/4R CTB92VG/5R CTB92VG/6R CTB92VG/7R CTB92VG/8R CTB92VG/9R CTB92VG/10R CTB92VG/11R CTB92VG/12R CTB92VG/13R POLES 2 3 4 5 6 7 8 9 10 11 12 13 LENGTH 10mm 15mm 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm 65mm TYPE NO. CTB92VG/14R CTB92VG/15R CTB92VG/16R CTB92VG/17R CTB92VG/18R CTB92VG/19R CTB92VG/20R CTB92VG/21R CTB92VG/22R CTB92VG/23R CTB92VG/24R CTB92VG/R POLES 14 15 16 17 18 19 20 21 22 23 24 LENGTH 70mm 75mm 80mm 85mm 90mm 95mm 100mm 105mm 110mm 115mm 120mm SOLAR PANELS TRANSFORMERS We operate a constant improvement policy, our products are subject to change without notice. Ver 1.1 +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com
CTB92VG/12S 价格&库存
很抱歉,暂时无法提供与“CTB92VG/12S”相匹配的价格&库存,您可以联系我们找货
