CTBP0108/2
CTBP0108/2
    CAMDENBOSS
    CAMDENBOSS - CTBP0108/2 - Wire-To-Board Terminal Block, 5.08 mm, 2 Ways, 22 AWG, 12 AWG, 3.31 mm², S...
CTBP0108/2 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D PLUGGABLES SCREWLESS 002 PCB TERMINAL BLOCKS 081 TERMINAL STRIPS 5.08mm pitch standard profile rising clamp terminal blocks Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS CTBP0108 • 2 and 3 pole double interlocking mechanism for increased strength • Moulded in green UL94-V0 flame retardant PA • Cable acceptance - 0.3-3.31mm2 (22-12AWG) • Professional rising clamp terminals • Guided pin alignment • Captive screws • C US approved 151 IP68 CONNECTORS 10.16mm Insulation resistance 500MΩ / 500V CTBP0108/3 3 15.24mm Withstand voltage AC1600V / 1min CTBP0108/4 4 20.32mm Contact resistance 20mΩ (max) CTBP0108/5 5 25.4mm Working temperature -40°C to +105°C CTBP0108/6 6 30.48mm Moulding UL94-V0 flame retardant PA CTBP0108/7 7 35.56mm Pin/terminal Tin plated brass CTBP0108/8 8 40.64mm Rising clamp Nickel plated brass CTBP0108/9 9 45.72mm Screw/torque M2.5 steel, zinc plated / 0.4Nm CTBP0108/10 10 50.8mm Recommended PCB hole size Ø1.5mm CTBP0108/11 11 55.88mm CTBP0108/12 12 60.96mm Ø1.50 10.50 2 5.00 LENGTH CTBP0108/2 3.14 5.08 5.08(xx-1) 0.60 PCB layout 0.80 5.00 Section: A-A K E Y F E AT U R E S | Rising clamp terminals CONNECT Standard profile | Double interlock mechanism 34 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 12 Vers 5.08xx A 3.50±0.3 INTERFACE MODULES AND RELAY BASES POLES 16A / 300V 0.60 14.10 158 PA R T N O . Rating 10.20 S P E C I F I C AT I O N 0.90 3.14 A 5.08 5.08(xx-1)
CTBP0108/2 价格&库存
很抱歉,暂时无法提供与“CTBP0108/2”相匹配的价格&库存,您可以联系我们找货
