CTBP9300/5AO
CTBP9300/5AO
    CAMDENBOSS
    CAMDENBOSS - CTBP9300/5AO - TERMINAL BLOCK, HEADER, 5POS, TH
CTBP9300/5AO 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D PLUGGABLES SCREWLESS 002 PCB TERMINAL BLOCKS 081 TERMINAL STRIPS 5mm pitch pluggable rising clamp terminal blocks Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS • • • • • • • • • • • S P E C I F I C AT I O N 2-12 pole solid block Professional rising clamp terminals Moulded in green UL94-V0 flame retardant PA66 Cable acceptance - 0.32 to 1.6mm2 (28-14AWG) solid and stranded cable Pluggable male and female connectors Open and closed headers Horizontal and vertical female plug styles Polarised mouldings Anti solder wicking Captive screws and guided pin alignment approved US , C Rating UL=15A/300V, VDE=20A/450V Insulation resistance 500M Ω/500V Withstand voltage AC2000V/1min Contact resistance 20mΩ (max) Working temperature -40°C to +105°C Moulding UL94-V0 flame retardant PA66 Pin/terminal Tin plated brass Rising clamp Brass, nickel plated Screw/torque M3 steel, zinc plated 0.5Nm Recommended PCB hole size ø1.7mm Female connector LENGTH 2 10mm CTBP9200/3 3 15mm CTBP9200/4 4 20mm CTBP9200/5 5 25mm CTBP9200/6 6 30mm CTBP9200/7 7 35mm CTBP9200/8 8 40mm CTBP9200/9 9 45mm CTBP9200/10 10 50mm CTBP9200/11 11 55mm CTBP9200/12 12 60mm CTBP9200 18.1 POLES CTBP9200/2 8.3 INTERFACE MODULES AND RELAY BASES PA R T N O . 5 15.05 158 Female vertical connector (standard) LENGTH 2 10mm CTBP92VG/3S 3 15mm CTBP92VG/4S 4 20mm CTBP92VG/5S 5 25mm CTBP92VG/6S 6 30mm CTBP92VG/7S 7 35mm CTBP92VG/8S 8 40mm CTBP92VG/9S 9 45mm CTBP92VG/10S 10 50mm CTBP92VG/11S 11 55mm CTBP92VG/12S 12 60mm CTBP92VG S 5 12.6 26 POLES CTBP92VG/2S 8.3 PA R T N O . 62 POLES LENGTH CTBP92VG/2R 2 10mm CTBP92VG/3R 3 15mm CTBP92VG/4R 4 20mm CTBP92VG/5R 5 25mm CTBP92VG/6R 6 30mm CTBP92VG/7R 7 35mm CTBP92VG/8R 8 40mm CTBP92VG/9R 9 45mm CTBP92VG/10R 10 50mm CTBP92VG/11R 11 55mm CTBP92VG/12R 12 60mm CTBP92VG R +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 12.6 5 26 PA R T N O . 8.3 CONNECT Female connector (reversed) SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS PCB mounting male vertical connector (closed ended) LENGTH 2 11.4mm CTBP9300/3 3 16.4mm CTBP9300/4 4 21.4mm CTBP9300/5 5 26.4mm CTBP9300/6 6 31.4mm CTBP9300/7 7 36.4mm CTBP9300/8 8 41.4mm CTBP9300/9 9 46.4mm CTBP9300/10 10 51.4mm CTBP9300/11 11 56.4mm CTBP9300/12 12 61.4mm CTBP9300 7.8 5 4 POLES CTBP9300/2 8.5 100 CIRCULAR CONNECTORS 151 11.4mm CTBP9350/3 3 16.4mm CTBP9350/4 4 21.4mm CTBP9350/5 5 26.4mm CTBP9350/6 6 31.4mm CTBP9350/7 7 36.4mm CTBP9350/8 8 41.4mm CTBP9350/9 9 46.4mm CTBP9350/10 10 51.4mm CTBP9350/11 11 56.4mm CTBP9350/12 12 61.4mm CTBP9350 4 7.8 12 LENGTH 2 IP68 CONNECTORS 2 POLES CTBP9350/2 095 WIRE TO BOARD CONNECTORS PCB mounting male horizontal connector (closed ended) PA R T N O . 081 TERMINAL STRIPS 3.9 1 12 PA R T N O . 158 INTERFACE MODULES AND RELAY BASES 8.5 5 1 POLES LENGTH CTBP9300/2AO 2 10mm CTBP9300/3AO 3 15mm CTBP9300/4AO 4 20mm CTBP9300/5AO 5 25mm CTBP9300/6AO 6 30mm CTBP9300/7AO 7 35mm CTBP9300/8AO 8 40mm CTBP9300/9AO 9 45mm CTBP9300/10AO 10 50mm CTBP9300/11AO 11 55mm CTBP9300/12AO 12 60mm 7.8 3.9 CTBP9300 AO 5 1 12 PA R T N O . 4 PCB mounting male vertical connector (open ended) 8.5 PCB mounting male horizontal connector (open ended) 10mm CTBP9350/3AO 3 15mm CTBP9350/4AO 4 20mm CTBP9350/5AO 5 25mm CTBP9350/6AO 6 30mm CTBP9350/7AO 7 35mm CTBP9350/8AO 8 40mm CTBP9350/9AO 9 45mm CTBP9350/10AO 10 50mm CTBP9350/11AO 11 55mm CTBP9350/12AO 12 60mm CTBP9350 AO 4 7.8 8.5 5 1 CONNECT LENGTH 2 12 POLES CTBP9350/2AO 2 PA R T N O . +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 63
CTBP9300/5AO 价格&库存
很抱歉,暂时无法提供与“CTBP9300/5AO”相匹配的价格&库存,您可以联系我们找货
