CTSN433/2
CTSN433/2
    CAMDENBOSS
CTSN433/2 数据手册
TERMINAL STRIPS 002 PCB TERMINAL DIECAST DIECAST BLOCKS ACCESSORIES ACCESSORIES 12 way nylon terminal strips 081 TERMINAL STRIPS Product overview S P E C I F I C AT I O N • Moulded from: Voltage Natural PA6 (standard, CTSN400) Working temperature Cream PA66 (CTSN500) Grey PA66 glass fibre (CTSN600) • Available with or without wire protection Moulding • UL94-V2 self extinguishing as standard • Passes 960°C glow-wire test according to EN Standard insert 60695-2-11 Terminal screws • Printing available on request Wire protectors • Easily cut to size • Supplied cut to length on request CTSN400 • Closed inserts (middle barrier) option • Captive terminal screws • C , , approved US , CTSN431-433 CTSN434-438 450VAC 750VAC (UL600VAC) CTSN400 CTSN500 CTSN600 -30°C to +110°C -30°C to +110°C -30°C to +160°C CTSN400 CTSN500 CTSN600 UL94-V2 PA6 UL94-V0 PA66 UL94-V0 PA66 + GF 095 WIRE TO BOARD CONNECTORS 100 Nickel-plated brass CIRCULAR CONNECTORS Zinc-plated steel CQ-15 Stainless steel 118 CTSN500 raised base IP68 CONNECTORS 158 INTERFACE MODULES AND RELAY BASES Part Numbers shown are for standard PA6 material (e.g. CTSN433/12) For CSTN500 PA66 material change first number to 5 (e.g. CTSN533/12) For CSTN600 PA66+GF material change first number to 6 (e.g. CTSN633/12) Standard type PA R T N O . PITCH/ UL R AT I N G WIRE PROTECTION INSERT DIAMETER CABLE A C C E P TA N C E TERMINAL SCREWS LENGTH W I DT H HEIGHT PITCH FIXING HOLE DIAMETER MAX CURRENT CTSN431/12W 8mm/20A No 3.2mm 4.0mm2/12AWG M3 94mm 18mm 15mm 8mm 2.8mm 32A CTSN431/12 8mm/15A Yes 3.2mm 2 2.5mm /14AWG M3 94mm 18mm 15mm 8mm 2.8mm 32A 2 CTSN433/12W 10mm/30A No 3.5mm 6.0mm /10AWG M3 116mm 21mm 16mm 10mm 2.8mm 41A CTSN433/12 10mm/20A Yes 3.5mm 4.0mm2/12AWG M3 116mm 21mm 16mm 10mm 2.8mm 41A 2 CTSN434/12W 12mm/50A No 4.4mm 10.0mm /8AWG M3.5 140mm 23mm 18mm 12mm 2.8mm 57A CTSN434/12 12mm/30A Yes 4.4mm 6.0mm2/10AWG M3.5 140mm 23mm 18mm 12mm 2.8mm 57A CTSN435/12W 13.5mm/65A No 6.0mm 2 16.0mm /6AWG M4 159mm 26mm 22.5mm 13.5mm 3.6mm 76A 2 CTSN435/12 13.5mm/65A Yes 6.0mm 10.0mm /8AWG M4 159mm 26mm 22.5mm 13.5mm 3.6mm 76A CTSN438/12W 18mm/85A No 7.5mm 3.5mm2/2AWG M5 177mm 31mm 27.5mm 15mm 3.4mm 101A Standard type, no wire protection L W P CONNECT H +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 EMS 613558 Vers Vers21 85 TERMINAL STRIPS 002 PCB TERMINAL DIECAST BLOCKS ACCESSORIES 081 TERMINAL STRIPS 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS Raised base PA R T N O . PITCH/ UL R AT I N G WIRE PROTECTION INSERT DIAMETER CABLE A C C E P TA N C E TERMINAL SCREWS LENGTH W I DT H HEIGHT PITCH FIXING HOLE DIAMETER MAX CURRENT CTSN431/12WR 8mm/20A No 3.2mm 4.0mm2/12AWG M3 94mm 18mm 17mm 8mm 2.8mm 32A CTSN431/12R 8mm/20A Yes 3.2mm 2.5mm2/14AWG M3 94mm 18mm 17mm 8mm 2.8mm 32A CTSN433/12WR 10mm/30A No 3.5mm 6.0mm2/10AWG M3 116mm 21mm 17.5mm 10mm 2.8mm 41A 2 CTSN433/12R 10mm/30A Yes 3.5mm 4.0mm /12AWG M3 116mm 21mm 17.5mm 10mm 2.8mm 41A CTSN434/12WR 12mm/50A No 4.4mm 10.0mm2/8AWG M3.5 140mm 23mm 20mm 12mm 2.8mm 57A CTSN434/12R 12mm/50A Yes 4.4mm 6.0mm /10AWG M3.5 140mm 23mm 20mm 12mm 2.8mm 57A CTSN435/12WR 13.5mm/65A No 6.0mm 16.0mm2/6AWG M4 159mm 26mm 26mm 13.5mm 3.6mm 76A CTSN435/12R 13.5mm/65A Yes 6.0mm 10.0mm2/8AWG M4 159mm 26mm 26mm 13.5mm 3.6mm 76A 2 Raised base types - provides increased isolation L 158 W P INTERFACE MODULES AND RELAY BASES H 3 K E Y F E AT U R E S | V0 types meet 960°C GWT CONNECT V2 or V0 material | Easily cut to required size 86 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614 EMS 613558 TERMINAL STRIPS 002 PCB TERMINAL DIECAST DIECAST BLOCKS ACCESSORIES ACCESSORIES Pluggable terminal strips 081 TERMINAL STRIPS Product overview CTSN MF S P E C I F I C AT I O N • Moulded in natural PA6, self extinguishing to UL94-V2 • Passes 960°C glow-wire test according to EN 60695-2-11 • Easily cut to size • Supplied cut to length on request • Printing available on request • approved Voltage (max 450V AC Working temperature -30°C to +110°C (PA6.6 to +150°C) Moulding UL94-V2 self extinguishing PA6 Conducting bush Nickel-plated brass Terminal screws Zinc-plated steel 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 118 Standard type IP68 CONNECTORS PA R T N O . PITCH/ UL R AT I N G INSERT DIAMETER CABLE A C C E P TA N C E TERMINAL SCREWS LENGTH W I DT H HEIGHT PITCH FIXING HOLE DIAMETER MAX CURRENT CTSN431/12MF 8mm/6A 2.9mm 4.0mm2/12AWG M3 94mm 16mm 15.5mm 8mm 2.75mm 17.5A CTSN433/12MF 10.25mm/10A 3.4mm 2.5mm2/14AWG M3 119.4mm 20.5mm 16.4mm 10.25mm 3.2mm 24A CTSN434/12MF 12.5mm/16A 4.3mm 6.0mm2/10AWG M3.5 143mm 23.5mm 19mm 12.3mm 3.5mm 57A 143 4.3 3.2 20.5 23.5 Ø5 Ø3.2 CTSN433/12MF CTSN431/12MF 20.5 10.2 8 3.4 16.4 3 2.85 20.5 3.2 10.2 15.5 Ø2.75 20.5 119.4 16 8 19 16 94 158 INTERFACE MODULES AND RELAY BASES CTSN434/12MF Strain relief Product overview CSR • Clamps external conductors in lighting fixtures according to EN60598 • Natural colour PA6 • Relieves strain on cables • Prevents conductors from twisting • Protects wire coating from abrasion and friction L H PA R T N O . TERMINAL STRIP LENGTH W I DT H HEIGHT CSR1 CTSN431 49.5mm 31mm 22.5mm CSR2 CTSN433 52.5mm 31mm 22.5mm CSR3 CTSN434 54.5mm 31mm 22.5mm W 20 P P Pluggable style | Easily cut to required size CONNECT K E Y F E AT U R E S | V0 to GWT 960°C +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 EMS 613558 Vers Vers21 87
CTSN433/2 价格&库存
很抱歉,暂时无法提供与“CTSN433/2”相匹配的价格&库存,您可以联系我们找货
