TERMINAL STRIPS
002
PCB TERMINAL
DIECAST
DIECAST
BLOCKS
ACCESSORIES
ACCESSORIES
Easy break terminal strips
081
TERMINAL STRIPS
Product overview
CTSOS
S P E C I F I C AT I O N
• Easily snapped to required
numbered of poles
• No remaining burrs
• No tools required
• Supplied with screws in
raised position
• 12 poles as standard
• Halogen free
• Passes 960°C glow-wire test
according to EN 60695-2-11
• Moulded in natural
UL94-V2 self extinguishing
PA6
• Black available on request (MOQ
may apply)
approved
Rating
450VAC
Glow wire test (EN 606 95-2-11)
960°C
Working temperature
-30°C to +110°C
Moulding
UL94-V2 self extinguishing PA6
Materials:
Insert
crew
Nickel plated brass
Zinc plated steel
095
WIRE TO BOARD
CONNECTORS
100
CIRCULAR
CONNECTORS
118
IP68 CONNECTORS
158
INTERFACE
MODULES AND
RELAY BASES
PA R T N O .
CONNECTING
CAPACITY
MIN CONDUCTOR
SECTION
TERMINAL
SCREWS
LENGTH
W I DT H
HEIGHT
PITCH
MAX
CURRENT
CTSOS431/12
2.5mm2
1mm2
M3
95.5mm
17.5mm
14.75mm
8mm
24A
CTSOS433/12
6mm2
2.5mm2
M3
118mm
19mm
15.6mm
10mm
41A
CTSOS434/12
10mm2
4mm2
M3.5
142mm
20.8mm
18.2mm
12mm
57A
CTSOS435/12
16mm2
6mm2
M4
160mm
23mm
21.2mm
13.5mm
76A
CTSOS438/12
35mm2
16mm2
M5
176.5mm
25.5mm
28mm
15mm
125A
K E Y F E AT U R E S
| Easily snapped to required size
CONNECT
Five size options
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
FM 28614
EMS 613558
Vers
Vers21
89
很抱歉,暂时无法提供与“CTSOS434/12BK”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+22.86386
- 10+22.09263
- 100+21.11970
- 250+20.70443
- 500+20.27729
- 1000+19.86201
