LIMIT SWITCHES
178
MICROSWITCHES
DIECAST
DIECAST
ACCESSORIES
ACCESSORIES
30mm wide pre-wired limit
switches
Product overview
TACTILE SWITCHES
S P E C I F I C AT I O N
30mm width
Pre wired. 1M cable standard
For 2M cable add suffix /2
Metal casing
Rated to IP67
Snap action contacts
US approved
C
Rating
400V
Cable
PVC 1m 4x0.75mm2
Impulse withstand voltage
4kV
Working temperture
-25°C to +70°C
Switching frequency
3600 cycles/h
Load factor
0.5
Short circuit protection
6A gG fuse
IP67 METAL CASING
PLUNGER TYPE
MAX ACTUATION SPEED
ACTUATION / NC OPERATION
CE70.0.AM
Plain plunger
0.5ms-1
15N/30N
CE70.0.BLM
Roller plunger with fixing nut
0.1ms-1
10N/30N
CE70.0.BM
Roller plunger
0.1ms-1
10N/30N
CE70.0.EM
Roller lever
1.5ms-1
0.08Nm/0.28Nm
CE70.0.FM
Adjustable nylon roller lever
-1
1.5ms
0.08Nm/0.28Nm
CE70.0.GM
Adjustable rod lever
1.5ms-1
0.08Nm/0.28Nm
CE70.0.HM
1.5ms-1
0.08Nm/0.28Nm
Plain plunger
FOOT SWITCHES
193
LIMIT SWITCHES
203
PIEZO SWITCHES
AND KEYPADS
8
3.5
30
70
60
84.8
21
44.8
35.8
8
191
3.5
Ø12
Ø12
22MM CONTROL
SWITCHES
Roller plunger
Ø10.4
Ø8
186
8
M12x1
24
30
7.5
30.5
Maxi 204
Ø6
66.5
18
86....158
66.5
18
66.5
29.5
6.5
5.5
19....91
27
48....118
Ø18
92
18
34.4
195
30
4.5
30
Ø14
Maxi 244
Roller lever
52
36.1
38.9
35.5
30
5.5
29
130
Maxi 179
SWITCH
66.5
Maxi 139
Ø3
18
CE 70
182
35.5
+44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com
We operate a constant improvement policy, our products are subject to change without notice.
Vers 1
199
很抱歉,暂时无法提供与“CE70.0.EM/2”相匹配的价格&库存,您可以联系我们找货
