CIME/E/SE1000S
CIME/E/SE1000S
    CAMDENBOSS
CIME/E/SE1000S 数据手册
I N T E R FA C E M O D U L E S & R E L AY B A S E S I N T E R FA C E M O D U L E S R E L AY B A S E S 002 PCB TERMINAL DIECAST BLOCKS ACCESSORIES 081 TERMINAL STRIPS Euro series 107mm empty modular interface support Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS 1INTERFACE 58 MODULES AND RELAY BASES CIME/E • Suitable for 107mm width PCB’s • Modular construction for easy assembly • Snap fit DIN Rail mounting fixtures • Moulded in grey UL 94-V0 flame retardant PA6 • Terminal blocks available in same colour • Integral marker facility • Integral DIN Rail mounting clip Wa l l m o u n t p l a t e s • Flush and raised surface mounting plates • Press into sides of end section without tool • Use foot element on long lengths with raised plates CIME/E/ T O TA L P C B LENGTH END SECTION SE1000S 11.5MM 20mm 2 38.5mm 2 55m 2 73.5mm 2 90mm 2 108.5mm 2 125mm 2 143.5mm 2 160mm 2 178.5mm 2 195mm 2 213.5mm 2 230mm 2 248.5mm 2 265mm 2 BASE ELEMENTS BE1850S 18.5MM PA R T N O . DESCRIPTION W I DT H CIME/E/BE1850S Base element 18.5mm CIME/E/BE3500S Base element 35mm CIME/E/BEF1850S Base element with foot 18.5mm CIME/E/BEF3500S Base element with foot 35mm CIME/E/SE1000S End section 11.5mm CIME/E/SEF1000S End section with foot 11.5mm PA R T N O . DESCRIPTION CIME/E/MPF Flush CIME/E/MPR Raised BE1850S 35MM PA R T C O U N T 2 1 3 1 1 1 1 1 1 1 3 1 4 2 4 2 5 3 5 3 6 4 6 4 7 5 7 5 8 6 8 6 9 7 9 Base elements 35 18.50 Base elements with foot 18.50 5.60 109 17.60 A B End section 11.50 17.60 C D 20 59.65 109 109 CONNECT 163 E 9.50 Foot element 11.50 18.68 17.6 35 109 5.60 26.60 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614
CIME/E/SE1000S 价格&库存
很抱歉,暂时无法提供与“CIME/E/SE1000S”相匹配的价格&库存,您可以联系我们找货
CIME/E/SE1000S
    • 1+17.249161+2.23863
    • 5+14.766135+1.91638
    • 10+13.7918710+1.78994
    • 30+12.3945530+1.60859
    • 50+11.7924650+1.53045
    • 100+11.02253100+1.43053
    • 250+10.08135250+1.30838
    • 500+9.42279500+1.22291
    • 1000+8.807201000+1.14302
    库存:66
