CPWP3I
CPWP3I
    CAMDENBOSS
    CAMDENBOSS - CPWP3I - Cable Joint, IP68, 3 Position, 8.5 mm, Black, Waterproof, In-Line
CPWP3I 数据手册
INTERCONNECTION IP68 Waterproof Assembly Connectors PCB TERMINAL BLOCKS INTERCONNECTION FUSES & FUSEHOLDERS LEDS & INDICATORS MINIATURE SWITCHES LIMIT & SAFETY SWITCHES • • • • • • • • • SPECIFICATION Voltage Rating Current Rating Min Wire Size OD Max Wire Size OD Contact Resistance Insulation Structure Temperature Rating IP Rating Mould Material Contact/Terminal Material Seal Material One piece construction. No risk of small electrical parts being dropped during installation Heavy duty. Robust and strong Compact, therefore more options to accommodate during installation Integrated terminal block designs means no small parts to drop. As this is a Field joiner, this is a key benefit Colour coded screws/ terminals make installation easier 250V 16A 5.5mm 8.5mm 10mΩ 500 MΩ at 500VDC -40°C ~ +105°C IP68 PA6 Nickel-Plated Brass Silicon Brail points to allow installation in low light conditions One piece construction removes possibility of mis-assembly EN61984 CE Approved CPWP3T CPWP3I CONTROL PRODUCTS INTERFACE MODULES & SUPPORTS Waterproof Field Assembly “T” Connector RELAY BASES DIN RAIL ENCLOSURES PART NO. CPWP3I CPWP3T CPWP3PM DESCRIPTION Waterproof Field Assembly Connector Waterproof Field Assembly “T” Connector Waterproof Field Installable Panel Mount Connector Waterproof Field Assembly Connector APPROVALS EN61984 & CE EN61984 & CE BATTERIES CPWP3PM TRANSFORMERS Waterproof Field Installable Panel Mount Connector 88 EL EC T RO N IC S & ENC LOSURES SPECIFICATION Voltage Rating Current Rating Min Wire Size OD Max Wire Size OD Contact Resistance Insulation Structure Temperature Rating IP Rating Mould Material Contact/Terminal Material Seal Material Number of Poles Durability Voltage We operate a constant improvement policy, We operate a constant improvement policy, products areasubject to improvement change without notice. operate constant Ver Ver 1.0 1.0 our ourWe products are subject to change withoutpolicy, notice. our products are subject to change without notice. (0)1638 716101 +44+44 (0)1638 716101 info@camdenboss.com +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com info@camdenboss.com www.camdenboss.com www.camdenboss.com 250V 16A 6mm 10mm 10mΩ 500 MΩ at 500VDC -40°C ~ +105°C IP68 PA66 Nickel-Plated Brass EPDM 70Sh A 3 1500VAC @ 60 s
CPWP3I 价格&库存
很抱歉,暂时无法提供与“CPWP3I”相匹配的价格&库存,您可以联系我们找货
