CSM30560D
CSM30560D
    CAMDENBOSS
CSM30560D 数据手册
Miniature Switches V3 Type Microswitches 5A, 10A & 15A • • • • • Rating 5A ,10A & 15A switching S.P.D.T. (15A to order) Coil spring mechanism 6.3mm (.250), 4.8mm (.187) quick connect solder & screw terminals Button, lever or roller actuators approved 15A CSM31500- CSM31510CSM31520CSM31530CSM31531CSM31540CSM31550CSM31560 10A CSM31000CSM31010CSM31020CSM31030CSM31040CSM31050CSM31060- 5A CSM30500CSM30510CSM30520CSM30530CSM30531CSM30540CSM30550CSM30560- PCb terminal blocks Specification Rating CSM3 CSM31000 CSM30500 Contact resistance Insulation strength Electrical Life Temperature range Material Terminal Actuator Style Button Short Lever Standard Lever Long Lever Long Wide Lever Simulated Roller Standard Roller Long Arm Roller Operating force max 3N 3N 0.7N 0.25N 0.25N 1.05N 3.2N 0.8N Release force max 0.7N 0.7N 0.15N 0.05N 0.07N 0.2N 0.6N 0.15N Case Button Actuator Contacts 10A 5A operating position 14.9 ± 0.4mm 15.8 ± 0.5mm 16.3 ± 1.2mm 17.2 ± 2.5mm 17.2 ± 2.5mm 19.5 ± 1.2mm 21.4 ± 0.6mm 21.4 ± 1.2mm 10A/250VAC 5A/250VAC 30mΩ max 100MΩ min/500VAC 50,000 operations min -10°C to +105°C PBT Bakelite Stainless steel AgNi10-Cu Silver Plated Brass 6.3mm quick connect as standard 4.8mm quick connect as standard Pre travel max 1.4mm 1.4mm 4mm 8mm 8mm 4mm 1.4mm 4mm Movement Differential 0.4mm 0.5mm 1mm 2mm 2mm 1mm 0.4mm 1mm Over travel min 1mm 1mm 2mm 4mm 4mm 2mm 1mm 2mm Interconnection fuses & Fuseholders LEDs & Indicators Miniature switches limit & Safety switches control products Interface modules & supports relay bases enclosures batteries transformers CSM310 Series replaces CMMS4 Series, example CSM31000C replaces CMMS4000C CSM305 Series replaces CMNS2 Series, example CSM30520D replaces CMNS2020D +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. 129 Ver 1.0 ELEC T RON IC S & ENC LOSURES
CSM30560D 价格&库存
很抱歉,暂时无法提供与“CSM30560D”相匹配的价格&库存,您可以联系我们找货
