CSTBP254V/3
CSTBP254V/3
    CAMDENBOSS
    CAMDENBOSS - CSTBP254V/3 - Wire-To-Board Terminal Block, 2.54 mm, 3 Ways, 28 AWG, 16 AWG, 1.3 mm², P...
CSTBP254V/3 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS 2.54mm screwless terminal blocks 081 TERMINAL STRIPS Product overview • • • • • • • S P E C I F I C AT I O N Interlocking modules Easily breakable to desired number of poles Guided pin alignment Choice of vertical or horizontal cable entry Moulded in green UL94-V0 PA66 0.08-1.3mm2 cable (28-16AWG) US approved C Rating 10A/300V Insulation withstand voltage AC1250V/1 min Insulation resistance 500MΩ at DC500V Operating temperature -40°C to +115°C Moulding UL94-V0 PA66 Pin/contact Tin plated brass Recommended PCB hole size 1.1mm 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 5 15.2mm CSTBP254V/6 6 17.8mm CSTBP254V/7 7 20.3mm CSTBP254V/8 8 22.9mm CSTBP254V/9 9 25.4mm CSTBP254V/10 10 27.9mm CSTBP254V/11 11 30.5mm CSTBP254V/12 12 33.0mm PA R T N O . POLES LENGTH CSTBP254H/2 2 7.6mm CSTBP254H/3 3 10.2mm CSTBP254H/4 4 12.7mm CSTBP254H/5 5 15.2mm CSTBP254H/6 6 17.8mm CSTBP254H/7 7 20.3mm CSTBP254H/8 8 1.05 2.54 9 25.4mm CSTBP254H/10 10 27.9mm CSTBP254H/11 11 30.5mm CSTBP254H/12 12 33.0mm 158 INTERFACE MODULES AND RELAY BASES 2.54 0.80 0.50 0.50 5.08 PCB LAYOUT 2.54x(N-1) 2.90 CSTBP254H 22.9mm CSTBP254H/9 12.60 2.54x(N+1) 13.60 1.05 13.60 CSTBP254V/5 2.54x(N+1) 12.60 12.7mm 13.60 4 3.50 10.2mm CSTBP254V/4 12.60 7.6mm 3 3.50 2 CSTBP254V/3 .20 CSTBP254V/2 IP68 CONNECTORS CSTBP254V Ø1 LENGTH .20 POLES Ø1 PA R T N O . 2.54 0.50 0.80 2.54 2.54x(N-1) 5.08 2.54x(N-1) K E Y F E AT U R E S | Modular design CONNECT Dual row pins | Space saving pitch size +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 85
CSTBP254V/3 价格&库存
很抱歉,暂时无法提供与“CSTBP254V/3”相匹配的价格&库存,您可以联系我们找货
