CTB1000/2
CTB1000/2
    CAMDENBOSS
CTB1000/2 数据手册
PCB TERMINAL BLOCKS PCB TERMINAL BLOCKS 5mm Pitch Low Profile 45˚ Rising Clamp Terminal Blocks INTERCONNECTION • • • • FUSES & FUSEHOLDERS • LEDs & INDICATORS LIMIT & SAFETY SWITCHES SPECIFICATION Rating CTB3000 Dielectric strength Impulse withstand voltage Working temperature Moulding Pin/terminal Rising clamp Screw/torque Recommended PCB hole size TYPE NO. CTB3000/2 CTB3000/3 CTB3000/4 CTB3000/5 CTB3000/6 CTB3000/7 CTB3000/8 CTB3000/9 CTB3000/10 CTB3000/11 CTB3000/12 POLES 2 3 4 5 6 7 8 9 10 11 12 24A/160V UL=16A/300V, VDE&IMQ=24A/130V ≥1.25kV 2.5kV 110°C UL94-V0 flame retardant PA Tinned, nickel plated brass Tinned, nickel plated brass M3 steel zinc plated, 0.5Nm ø1.3mm 45 2. MINIATURE SWITCHES • • • • 2 & 3 pole interlocking 4-12 pole pre-assembled 45° mounting Moulded in grey UL94-V0 flame retardant PA Professional rising clamp terminals 0.2-4.0mm2 (30-12AWG) solid cable 0.2-2.5mm2 (30-12AWG) stranded cable Captive screw  , , approved LENGTH 10mm 15mm 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm CONTROL PRODUCTS INTERFACE MODULES & SUPPORTS RELAY BASES DIN RAIL ENCLOSURES BATTERIES SOLAR TRANSFORMERS PANELS TRANSFORMERS 5mm Pitch Standard Profile Screw Terminal Blocks • • • • • • • • • 2 & 3 pole interlocking 4-12 pole solid block end stackable Guided pin alignment Moulded in grey UL94-V0 flame retardant PC Wire protector terminals 0.5-4.0mm2 (30-14AWG) solid cable 0.5-2.5mm2 (30-14AWG) stranded cable Anti solder wicking terminals , , approved SPECIFICATION Rating CTB1000 Dielectric strength Impulse withstand voltage Working temperature Moulding Pin/terminal Wire protector Screw/torque Recommended PCB hole size TYPE NO. CTB1000/2 CTB1000/3 CTB1000/4 CTB1000/5 CTB1000/6 CTB1000/7 CTB1000/8 CTB1000/9 CTB1000/10 CTB1000/11 CTB1000/12 16 POLES 2 3 4 5 6 7 8 9 10 11 12 VerVer 1.01.1 EL EC T RO N IC S & ENC LOSURES 24A/400V UL=16A/300V, VDE&IMQ=24A/450V ≥2.5kV 4kV 85°C UL94-V0 flame retardant PC Tinned, nickel plated brass Tinned, nickel plated brass M3 steel zinc plated, 0.5Nm ø1.1mm LENGTH 10mm 15mm 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm We operate a constant improvement policy, We operate a constant improvement policy, our products are subject to change without notice. We operate a constant improvement policy, our products are subject to change without notice. our products are subject to change without notice. (0)1638 716101 +44+44 (0)1638 716101 info@camdenboss.com +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com info@camdenboss.com www.camdenboss.com www.camdenboss.com
CTB1000/2 价格&库存
很抱歉,暂时无法提供与“CTB1000/2”相匹配的价格&库存,您可以联系我们找货
