PCB Terminal blocks
5mm Pitch Standard Profile 90˚ Screw Terminal
• 2 & 3 pole interlocking
• 2-12 pole solid block
end stackable
• Guided pin alignment
• Moulded in grey UL94-V0
flame retardant PC
• Wire protector terminals
• 0.5-4.0mm2 (30-14AWG)
solid cable
• 0.5-2.5mm2 (30-14AWG)
stranded cable
• Anti solder wicking terminals
, , , approved
Specification
Rating
CTB1050
Dielectric strength
Impulse withstand voltage
Working temperature
Moulding
Pin/terminal
Rising clamp
Screw/torque
Recommended PCB hole size
Type No.
CTB1050/2
CTB1050/3
CTB1050/4
CTB1050/5
CTB1050/6
CTB1050/7
CTB1050/8
CTB1050/9
CTB1050/10
CTB1050/11
CTB1050/12
Poles
2
3
4
5
6
7
8
9
10
11
12
Length
10mm
15mm
20mm
25mm
30mm
35mm
40mm
45mm
50mm
55mm
60mm
24A/250V
UL=16A/300V, VDE&IMQ=24A/450V
≥2.5kV
4kV
85°C
UL94-V0 flame retardant PC
Tinned, nickel plated brass
Nickel plated brass
M3 steel zinc plated, 0.5Nm
ø1.1mm
PCb
terminal
blocks
Interconnection
fuses &
Fuseholders
LEDs &
Indicators
Miniature
switches
For other dimensions see CTB1000
limit &
Safety
switches
5mm Pitch Commercial Standard Profile Screw Terminal
• 2
• E
nd stackable
• M
flame retardant PC
• W
• 0.5-4.0mm2 (30-12AWG)
solid cable
• 0.5-2.5mm2 (30-12AWG)
stranded cable
• C
aptive screw
• A
• G
uided pin alignment
• 13
& 14 pole avaliable
on request
, , , approved
Specification
Rating
CTB1500
Dielectric strength
Working temperature
Moulding
Pin/terminal
Wire protector
Screw/torque
Type No.
CTB1500/2
CTB1500/3
CTB1500/4
CTB1500/5
CTB1500/6
CTB1500/7
CTB1500/8
CTB1500/9
CTB1500/10
CTB1500/11
CTB1500/12
+44 (0)1638 716101
info@camdenboss.com
www.camdenboss.com
Poles
2
3
4
5
6
7
8
9
10
11
12
24A/250V
UL=18A/300V, VDE&IMQ=24A/250V
≥2kV
4kV
85°C
Nickel plated brass
M2.5 steel zinc plated, 0.5Nm
ø1.1mm
Length
10mm
15mm
20mm
25mm
30mm
35mm
40mm
45mm
50mm
55mm
60mm
We operate a constant improvement policy,
our products are subject to change without notice.
control
products
Interface
modules &
supports
relay
bases
enclosures
batteries
transformers
13
Ver 1.0
ELEC T RON IC S & ENC LOSURES
很抱歉,暂时无法提供与“CTB1050/10”相匹配的价格&库存,您可以联系我们找货
