CTB9208/10
CTB9208/10
    CAMDENBOSS
CTB9208/10 数据手册
PCB TERMINAL BLOCKS PCB TERMINAL BLOCKS INTERCONNECTION FUSES & FUSEHOLDERS 5.08mm Pitch Pluggable Rising Clamp Terminal Blocks • 2  -24 pole solid block • Pluggable male-female connectors • Open & closed headers • Horizontal & vertical female plug styles • Polarised mouldings • Moulded in green UL94-V0 flame retardant PA • Professional rising clamp terminals • 0.2-2.5mm2 (30-12AWG) solid & stranded cable • Anti solder wicking • Captive screws • Guided pin alignment • , , approved SPECIFICATION Rating Dielectric strength Impulse withstand voltage Working temperature Moulding Pin/terminal Rising clamp Screw/torque Recommended PCB hole size 12A/320V UL=12A/300V, VDE&IMQ=20A/320V ≥2.5kV 4kV 110°C UL94-V0 flame retardant PA Copper alloy, NI & SN Copper alloy, NI & SN M3 steel zinc plated, 0.5Nm ø1.4mm LEDs & INDICATORS Female connector MINIATURE SWITCHES LIMIT & SAFETY SWITCHES CONTROL PRODUCTS INTERFACE MODULES & SUPPORTS RELAY BASES DIN RAIL ENCLOSURES TYPE NO. CTB9208/2 CTB9208/3 CTB9208/4 CTB9208/5 CTB9208/6 CTB9208/7 CTB9208/8 CTB9208/9 CTB9208/10 CTB9208/11 CTB9208/12 CTB9208/13 POLES 2 3 4 5 6 7 8 9 10 11 12 13 LENGTH 10.2mm 15.2mm 20.3mm 25.4mm 30.5mm 35.6mm 40.6mm 45.7mm 50.8mm 55.9mm 61mm 66mm TYPE NO. CTB9208/14 CTB9208/15 CTB9208/16 CTB9208/17 CTB9208/18 CTB9208/19 CTB9208/20 CTB9208/21 CTB9208/22 CTB9208/23 CTB9208/24 POLES 14 15 16 17 18 19 20 21 22 23 24 LENGTH 71.1mm 76.2mm 81.3mm 86.4mm 91.4mm 96.5mm 101.6mm 106.7mm 111.8mm 116.8mm 121.9mm POLES 14 15 16 17 18 19 20 21 22 23 24 LENGTH 71.1mm 76.2mm 81.3mm 86.4mm 91.4mm 96.5mm 101.6mm 106.7mm 111.8mm 116.8mm 121.9mm POLES 14 15 16 17 18 19 20 21 22 23 24 LENGTH 71.1mm 76.2mm 81.3mm 86.4mm 91.4mm 96.5mm 101.6mm 106.7mm 111.8mm 116.8mm 121.9mm CTB9208 Female connector vertical (standard) TYPE NO. CTB92VJ/2S CTB92VJ/3S CTB92VJ/4S CTB92VJ/5S CTB92VJ/6S CTB92VJ/7S CTB92VJ/8S CTB92VJ/9S CTB92VJ/10S CTB92VJ/11S CTB92VJ/12S CTB92VJ/13S POLES 2 3 4 5 6 7 8 9 10 11 12 13 LENGTH 10.2mm 15.2mm 20.3mm 25.4mm 30.5mm 35.6mm 40.6mm 45.7mm 50.8mm 55.9mm 61mm 66mm TYPE NO. CTB92VJ/14S CTB92VJ/15S CTB92VJ/16S CTB92VJ/17S CTB92VJ/18S CTB92VJ/19S CTB92VJ/20S CTB92VJ/21S CTB92VJ/22S CTB92VJ/23S CTB92VJ/24S CTB92VJ/S BATTERIES Female connector vertical (reversed) SOLAR PANELS TRANSFORMERS TYPE NO. CTB92VJ/2R CTB92VJ/3R CTB92VJ/4R CTB92VJ/5R CTB92VJ/6R CTB92VJ/7R CTB92VJ/8R CTB92VJ/9R CTB92VJ/10R CTB92VJ/11R CTB92VJ/12R CTB92VJ/13R POLES 2 3 4 5 6 7 8 9 10 11 12 13 LENGTH 10.2mm 15.2mm 20.3mm 25.4mm 30.5mm 35.6mm 40.6mm 45.7mm 50.8mm 55.9mm 61mm 66mm TYPE NO. CTB92VJ/14R CTB92VJ/15R CTB92VJ/16R CTB92VJ/17R CTB92VJ/18R CTB92VJ/19R CTB92VJ/20R CTB92VJ/21R CTB92VJ/22R CTB92VJ/23R CTB92VJ/24R CTB92VJ/R We operate a constant improvement policy, our products are subject to change without notice. Ver 1.1 +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com
CTB9208/10 价格&库存
很抱歉,暂时无法提供与“CTB9208/10”相匹配的价格&库存,您可以联系我们找货
