CTB9350/12A
CTB9350/12A
    CAMDENBOSS
CTB9350/12A 数据手册
PCB TERMINAL BLOCKS PCB mounting male horizontal (closed ended) TYPE NO. CTB9350/2A CTB9350/3A CTB9350/4A CTB9350/5A CTB9350/6A CTB9350/7A CTB9350/8A CTB9350/9A CTB9350/10A CTB9350/11A CTB9350/12A CTB9350/13A POLES 2 3 4 5 6 7 8 9 10 11 12 13 LENGTH 11.2mm 16.2mm 21.2mm 26.2mm 31.2mm 36.2mm 41.2mm 46.2mm 51.2mm 56.2 61.2mm 66.2mm TYPE NO. CTB9350/14A CTB9350/15A CTB9350/16A CTB9350/17A CTB9350/18A CTB9350/19A CTB9350/20A CTB9350/21A CTB9350/22A CTB9350/23A CTB9350/24A POLES 14 15 16 17 18 19 20 21 22 23 24 PCB TERMINAL BLOCKS CTB9350 LENGTH 71.2mm 76.2mm 81.2mm 86.2mm 91.2mm 96.2mm 101.2mm 106.2mm 111.2mm 116.2mm 121.2mm INTERCONNECTION FUSES & FUSEHOLDERS LEDs & INDICATORS PCB mounting male horizontal (open ended) TYPE NO. CTB9350/2AO CTB9350/3AO CTB9350/4AO CTB9350/5AO CTB9350/6AO CTB9350/7AO CTB9350/8AO CTB9350/9AO CTB9350/10AO CTB9350/11AO CTB9350/12AO CTB9350/13AO POLES 2 3 4 5 6 7 8 9 10 11 12 13 LENGTH 10mm 15mm 20mm 25mm 30mm 35mm 40mm 45mm 50mm 55mm 60mm 65mm TYPE NO. CTB9350/14AO CTB9350/15AO CTB9350/16AO CTB9350/17AO CTB9350/18AO CTB9350/19AO CTB9350/20AO CTB9350/21AO CTB9350/22AO CTB9350/23AO CTB9350/24AO POLES 14 15 16 17 18 19 20 21 22 23 24 LENGTH 70mm 75mm 80mm 85mm 90mm 95mm 100mm 105mm 110mm 115mm 120mm MINIATURE SWITCHES CTB9350/AO LIMIT & SAFETY SWITCHES CONTROL PRODUCTS INTERFACE MODULES & SUPPORTS RELAY BASES DIN RAIL ENCLOSURES BATTERIES SOLAR PANELS TRANSFORMERS +44 (0)1638 716101 info@camdenboss.com www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Ver 1.2
CTB9350/12A 价格&库存
很抱歉,暂时无法提供与“CTB9350/12A”相匹配的价格&库存,您可以联系我们找货
