CTB9352/4
CTB9352/4
    CAMDENBOSS
    CAMDENBOSS - CTB9352/4 - Terminal Block, Header, 5 mm, 4 Ways, Through Hole Right Angle
CTB9352/4 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D PLUGGABLES SCREWLESS ECONOMY RANGE 5mm pitch pluggable rising clamp terminal blocks Product overview 17 3 15mm CTB9202/4 4 20mm CTB9202/5 5 25mm CTB9202/6 6 30mm CTB9202/7 7 35mm CTB9202/8 8 40mm CTB9202/9 9 45mm CTB9202/10 10 50mm CTB9202/11 11 55mm CTB9202/12 12 60mm PA R T N O . POLES LENGTH CTB922VG/2S 2 10mm CTB922VG/3S 3 15mm CTB922VG/4S 4 20mm CTB922VG/5S 5 25mm CTB922VG/6S 6 30mm CTB922VG/7S 7 35mm CTB922VG/8S 8 40mm CTB922VG/9S 9 45mm CTB922VG/10S 10 50mm CTB922VG/11S 11 55mm CTB922VG/12S 12 60mm PA R T N O . POLES LENGTH CTB922VG/2R 2 10mm CTB922VG/3R 3 15mm CTB922VG/4R 4 20mm CTB922VG/5R 5 25mm CTB922VG/6R 6 30mm CTB922VG/7R 7 35mm CTB922VG/8R 8 40mm CTB922VG/9R 9 45mm CTB922VG/10R 10 50mm CTB922VG/11R 11 55mm CTB922VG/12R 12 60mm Tin plated, phosphor bronze Screw/torque M3 steel, tin plated 0.4Nm Recommended PCB hole size ø1.4mm CTB9202 8.1 8.1 CTB922VG S 25.9 CTB9202/3 UL94-V0 flame retardant PA66 Wire protector CTB922VG R 25.9 10mm -40°C to +105°C Mouldings 17.6 LENGTH 2 20m Ω Working temperature 17.7 POLES CTB9202/2 AC1000V/1min Contact resistance 2.5 PA R T N O . 1000M Ω/1000V Withstand voltage 17.6 E CO N O M Y R A N G E P C B T E R M I N A L B LO C KS • • • 15A 300V Insulation resistance 12.4 • 2-12 pole solid block Up to 24 poles available Pluggable male-female connectors Professional rising clamp terminals Closed headers Polarised mouldings Moulded in green UL94-V0 flame retardant PA66 0.2-3.3mm2 (24-12AWG) solid & stranded cable Captive screws Guided pin alignment approved 12.4 • • • • • • • S P E C I F I C AT I O N Rating +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 FM 28614 EMS 613558 SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS ECONOMY RANGE 2 11.2mm CTB9302/3 3 16.2mm CTB9302/4 4 21.2mm CTB9302/5 5 26.2mm CTB9302/6 6 31.2mm CTB9302/7 7 36.2mm CTB9302/8 8 41.2mm CTB9302/9 9 46.2mm CTB9302/10 10 51.2mm CTB9302/11 11 56.2 CTB9302/12 12 61.2mm PA R T N O . POLES LENGTH CTB9352/2 2 11.2mm CTB9352/3 3 16.2mm CTB9352/4 4 21.2mm CTB9352/5 5 26.2mm CTB9352/6 6 31.2mm CTB9352/7 7 36.2mm CTB9352/8 8 41.2mm CTB9352/9 9 46.2mm CTB9352/10 10 51.2mm CTB9352/11 11 56.2 CTB9352/12 12 61.2mm PA R T N O . POLES LENGTH CTB9352/2AO 2 11.2mm CTB9352/3AO 3 16.2mm CTB9352/4AO 4 21.2mm CTB9352/5AO 5 26.2mm CTB9352/6AO 6 31.2mm CTB9352/7AO 7 36.2mm CTB9352/8AO 8 41.2mm CTB9352/9AO 9 46.2mm CTB9352/10AO 10 51.2mm CTB9352/11AO 11 56.2 CTB9352/12AO 12 61.2mm 12.2±0.1 3.9±0.2 5.0 CTB9352 12.3 CTB9352 AO 12.3 E CO N O M Y R A N G E P C B T E R M I N A L B LO C KS CTB9302/2 1.0x1.0 CTB9302 3.7 LENGTH 8.6 POLES 8.6 PA R T N O . +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. FM 28614 EMS 613558 Vers 1 18
CTB9352/4 价格&库存
很抱歉,暂时无法提供与“CTB9352/4”相匹配的价格&库存,您可以联系我们找货
