CTBP04VZ/3
CTBP04VZ/3
    CAMDENBOSS
    Conn Terminal Block F 3 POS 9.5mm Solder ST Thru-Hole 30A
CTBP04VZ/3 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS 9.5mm pitch high power rising clamp terminal blocks Product overview 081 TERMINAL STRIPS CTBP04VZ • 2 and 3 pole double interlocking mechanism for increased strength • Professional rising clamp terminals • High profile • Moulded in green UL94-V0 flame retardant PA66 • Cable acceptance - 0.13-5.26mm2 (2610AWG) • Guided pin alignment • 32A 630V • C approved US , 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 Insulation resistance Withstand voltage 500M Ω/500V AC2000V/1min Contact resistance 20mΩ (max) Working temperature -40°C to +105°C Moulding Pin/terminal Rising clamp Screw/torque Recommended PCB hole size UL94-V0 flame retardant PA66 Tin plated brass Brass, nickel plated M3 steel, zinc plated 0.5Nm ø1.6mm PA R T N O . POLES LENGTH CTBP04VZ/2 2 19.0mm CTBP04VZ/3 3 28.5mm CTBP04VZ/4 4 38.0mm CTBP04VZ/5 5 47.5mm CTBP04VZ/6 6 57.0mm CTBP04VZ/7 7 66.5mm CTBP04VZ/8 8 76.0mm CTBP04VZ/9 9 85.5mm CTBP04VZ/10 10 95.0mm CTBP04VZ/11 11 104.5mm CTBP04VZ/12 12 114.0mm 158 0.6 INTERFACE MODULES AND RELAY BASES 21 Rating UL=30A/300V, VDE=32A/630V 4.5 S P E C I F I C AT I O N 12.6 IP68 CONNECTORS 9.5 4.75 5.25 K E Y F E AT U R E S | Double interlock mechanism | Professional rising clamp CONNECT High power 32A +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 45
CTBP04VZ/3 价格&库存
很抱歉,暂时无法提供与“CTBP04VZ/3”相匹配的价格&库存,您可以联系我们找货
CTBP04VZ/3
  • 1+9.66998
  • 10+8.50721
  • 100+7.85463
  • 500+7.35630
  • 1000+7.09527
  • 2500+6.82238
库存:34
