CTBP0508/2
CTBP0508/2
    CAMDENBOSS
    Conn Terminal Block F 2 POS 5.08mm Solder ST Thru-Hole 8A
CTBP0508/2 数据手册
P C B T E R M I N A L B LO C KS S TA N D A R D SCREWLESS PLUGGABLES 002 Product overview 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS 158 INTERFACE MODULES AND RELAY BASES CTBP0508 • 2 and 3 pole double interlocking mechanism for increased strength • Professional rising clamp terminals • Low profile • Moulded in green UL94-V0 flame retardant PA66 • Cable acceptance - 0.4-1.3mm2 (2616AWG) • Guided pin alignment • C approved US , S P E C I F I C AT I O N PA R T N O . POLES LENGTH Rating UL=8A/300V, VDE=15A/250V CTBP0508/2 2 10.16mm Insulation resistance 500M Ω/500V CTBP0508/3 3 15.24mm Withstand voltage AC2000V/1min CTBP0508/4 4 20.32mm Contact resistance 20mΩ (max) CTBP0508/5 5 25.4mm Working temperature -40°C to +105°C CTBP0508/6 6 30.48mm Moulding UL94-V0 flame retardant PA66 CTBP0508/7 7 35.56mm Tin plated brass CTBP0508/8 8 40.64mm CTBP0508/9 9 45.72mm CTBP0508/10 10 50.8mm CTBP0508/11 11 55.88mm CTBP0508/12 12 60.96mm Pin/terminal Rising clamp Screw/torque Recommended PCB hole size Brass, nickel plated M2.5 steel, zinc plated 0.4Nm ø1.3mm 8.5 TERMINAL STRIPS 10.2 081 5.08mm pitch low profile rising clamp terminal blocks 0.9 4 PCB TERMINAL BLOCKS 4 K E Y F E AT U R E S | Professional rising clamp CONNECT Low profile | Double interlock mechanism 30 +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 0.6 5.08
CTBP0508/2 价格&库存
很抱歉,暂时无法提供与“CTBP0508/2”相匹配的价格&库存,您可以联系我们找货
