CTBP1000/3
CTBP1000/3
    CAMDENBOSS
    CAMDENBOSS - CTBP1000/3 - 5MM STANDARD PROFILE TERMINAL BLOCK 3P
CTBP1000/3 数据手册
SCREWLESS PLUGGABLES S TA N D A R D P C B T E R M I N A L B LO C KS 002 PCB TERMINAL BLOCKS 5mm pitch standard profile screw terminal blocks Product overview 081 TERMINAL STRIPS CTBP1000 • • • • • 2 and 3 pole interlocking Wire protector terminals Standard profile Moulded in UL94-V0 flame retardant PA66 Cable acceptance - 0.6-1.6mm2 (2214AWG) • Guided pin alignment • Anti solder wicking terminals • C approved US , 095 WIRE TO BOARD CONNECTORS 100 CIRCULAR CONNECTORS 151 IP68 CONNECTORS PA R T N O . POLES LENGTH Rating UL=16A/300V, VDE=24A/250V CTBP1000/2 2 10mm Insulation resistance 500M Ω/500V CTBP1000/3 3 15mm Withstand voltage AC2000V/1min CTBP1000/4 4 20mm 20mΩ (max) Working temperature -40°C to +105°C Moulding UL94-V0 flame retardant PA66 Pin/terminal Tin plated brass Wire protector Phosphor bronze, nickel plated Screw/torque M2.5 steel, zinc plated 0.4Nm Recommended PCB hole size ø1.5mm CTBP1000/5 5 25mm CTBP1000/6 6 30mm CTBP1000/7 7 35mm CTBP1000/8 8 40mm CTBP1000/9 9 45mm CTBP1000/10 10 50mm CTBP1000/11 11 55mm CTBP1000/12 12 60mm *5.00±0.3 5.0xx 0.50 158 INTERFACE MODULES AND RELAY BASES *3.50±0.3 Contact resistance 0.50 9.00 12.50 S P E C I F I C AT I O N Ø1.00 *5.00±0.1 *5.00(xx-1) K E Y F E AT U R E S | Standard profile CONNECT Wire protector terminals | Interlock mechanism +44 (0)1638 716101 | sales@camdenboss.com | www.camdenboss.com We operate a constant improvement policy, our products are subject to change without notice. Vers 1 21
CTBP1000/3 价格&库存
很抱歉,暂时无法提供与“CTBP1000/3”相匹配的价格&库存,您可以联系我们找货
